09 silverado viper 5x06 with flcan bypass
esolomon86
Posted: March 25, 2016 at 3:42 PM / IP Logged Link to Post Post Reply Quote esolomon86
My problem- best buy install line is 4 weeks out
The wire diagram for the flcan is self explanatory as far as what is needed on bypass,I have already had it flashed as a favor not to return item, the viper has no diagram as far as what is needed to be wired on th viper system itself ex. Power inputs starter I am using d2d, I need to know per harness on viper what needs to be wired (main harness, remote start harness, 24 pin harness) for this flcan bypass and viper 5706 system thank you in advance
2009 chevy silverado 2500 6.0gas
Flcan flc-al (dl)-gm10-en
Viper 5706 (5X06)
Eric
esolomon86
Posted: March 25, 2016 at 11:02 PM / IP Logged Link to Post Post Reply Quote esolomon86
Ok so I've been reading posts for days on this website and finally have found this if it isn't obvious this is my first r/s install and I just t e Ying not to mess it up. I was hoping for more detailed wiring diagram but the only one that made any since was the diagram for the bypass and now I'm at a standstill here is the bypass
Viper 5706
Main Harness, 6-pin connector
1 RED (+)12VDC CONSTANT INPUT                           +12V Constant
2 BLACK (-) CHASSIS GROUND                                   Chassis Ground
3 BROWN (+) SIREN OUTPUT                                      Siren
4 WHITE/ BROWN PARKING LIGHT ISOLATION          Not Used
5 WHITE PARKING LIGHT OUTPUT   *Set to (-)           Gray/Black @ BCM Brown Plug
6 ORANGE (-) 500mA GROUND WHEN ARMED          Not Used
Door Lock, 3-pin connector
1 BLUE (-) 500mA UNLOCK OUTPUT                          Handled by D2D
2 EMPTY NOT USED
3 GREEN (-) 500mA LOCK OUTPUT                            Handled by D2D
Remote Start, 10-pin heavy gauge connector
1 NC No Connection
2 RED / BLACK (+) FUSED 12V ACC/STARTER INPUT               thick Red @ ignition switch harness
3 PINK/BLACK (+) FLEX RELAY INPUT 87A                               Not used
4 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT             thick White @ ignition switch harness
5 RED (+) FUSED 12V IGNITION 1 INPUT                                   thick RED / White @ ignition switch harness
6 GREEN (+) STARTER INPUT (KEY SIDE)                                 thick Yellow @ ignition switch harness
7 VIOLET (+) STARTER OUTPUT (CAR SIDE)                            thick Yellow @ ignition switch harness
8 ORANGE (+) ACCESSORY OUTPUT                                        thick Orange @ ignition switch harness
9 RED / WHITE (+) FUSED 12V IGNITION 2 / Flex                        thick Red @ ignition switch harness
10 PINK (+) IGNITION 1 INPUT/OUTPUT                                     thick Pink @ ignition switch harness
Auxiliary/Shutdown/Trigger Harness, 24-pin connector
1 PNK/WHITE (-) 200mA Ignition 2/Flex OUTPUT                                       Not Used
2 BLUE/WHITE (-) 200mA 2ND STATUS /REAR DEFOG OUTPUT           Not Used
3 RED / WHITE (-) 200mA TRUNK RELEASE OUTPUT                               Not Used
4 BLACK / YELLOW (-) 200mA DOME LIGHT OUTPUT                               Not Used
5 DARK BLUE (-) 200mA STATUS OUTPUT                                              Handled by D2D
6 WHITE/ BLACK (-) 200mA AUX 3 OUTPUT                                              Not Used
7 WHITE/ VIOLET (-) 200mA AUX 1 OUTPUT                                             Not Used
8 ORANGE / BLACK (-) 200mA AUX 4 OUTPUT                                          Not Used
9 GRAY (-) HOOD PIN INPUT (NC OR NO)                                                To kit supplied hood pin
10 BLUE (-) TRUNK PIN/INSTANT TRIGGER (N/C OR N/O)                     Not Used
11 WHITE/ BLUE ACTIVATION INPUT                                                        Not Used
12 VIOLET/WHITE* TACHOMETER INPUT                                                Handled by D2D
13 BLACK/ WHITE** (-) NEUTRAL SAFETY /PARKING BRAKE IN            Chassis Ground ( auto trans only )
14 GREEN/ BLACK (-) 200mA FACTORY ALARM DISARM OUT               Not Used
15 GREEN* (-) DOOR INPUT        Handled by D2D
16 BROWN / BLACK (-) 200mA HORN HONK OUTPUT                               Black @ BCM Gray Plug
17 PINK (-) 200mA IGNITION 1 OUTPUT                                                   Not Used
18 VIOLET* (+) DOOR INPUT        Not Used
19 VIOLET/BLACK (-) 200mA AUX 2 OUTPUT                                          Not Used
20 BROWN (+) BRAKE SHUTDOWN INPUT                                              White @ Brake Pedal
21 VIOLET / YELLOW (-) 200mA STARTER OUTPUT                                 Not Used
22 GRAY/BLACK (-) DIESEL WAIT TO START INPUT                               Not Used
23 ORANGE (-) 200mA ACCESSORY OUTPUT                                          To extra Relay Pin 85
24 GREEN / WHITE (-) 200mA FACTORY ALARM ARM OUTPUT              Not Used
Need a bit of clarification, buy only o the bypass, it controls pretty much everything correct? And as far as the top part of this, this was written for a different bypass, so I'm trying to do a process of elimination, to determine.
Eric
racerjames76
Silver - Posts: 581
Posted: March 31, 2016 at 8:06 AM / IP Logged Link to Post Post Reply Quote racerjames76
esolomon86 wrote:
<snip><snip/>
Viper 5706
1 RED (+)12VDC CONSTANT INPUT thick RED / BLACK @ BEHIND JUNCTION BOX LEFT SIDE OF
5 WHITE PARKING LIGHT OUTPUT   *Set to (-)  LIGHT BLUE @ EITHER BCM OR HEAD LIGHT SWITCH
2 EMPTY NOT USED
1 NC No Connection
2 RED / BLACK (+) FUSED 12V ACC/STARTER INPUT               thick RED / BLACK @ BEHIND JUNCTION BOX LEFT SIDE OF DASH
4 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT NOT USED
5 RED (+) FUSED 12V IGNITION 1 INPUT          thick RED / BLACK @ BEHIND JUNCTION BOX LEFT SIDE OF
6 GREEN (+) STARTER INPUT (KEY SIDE)        NOT USED
7 VIOLET (+) STARTER OUTPUT (CAR SIDE)   NOT USED
8 ORANGE (+) ACCESSORY OUTPUT  THIN BROWN ACCESSORY  @ USE FLASHLOGIC DIAGRAM
9 RED / WHITE (+) FUSED 12V IGNITION 2 / Flex thick RED / BLACK @ BEHIND JUNCTION BOX LEFT SIDE OF
10 PINK (+) IGNITION 1 INPUT/OUTPUT THIN PINK IGNITION  @ USE FLASHLOGIC DIAGRAM
16 BROWN / BLACK (-) 200mA HORN HONK OUTPUT      Black @ BCM Gray Plug NOT SURE ABOUT THIS
20 BROWN (+) BRAKE SHUTDOWN INPUT        White @ Brake Pedal SHOULD BE PROVIDED BY D2D
23 ORANGE (-) 200mA ACCESSORY OUTPUT   NOT USED
I believe that will help.
To master and control electricity is perfection. *evil laugh*
racerjames76
Silver - Posts: 581
Posted: March 31, 2016 at 8:11 AM / IP Logged Link to Post Post Reply Quote racerjames76
If it helps to understand, that truck is Remote Start Ready. Which means an interface can do most of the work. There are easier solutions and in fact some that just simply plug in. The flash logic diagram gives all the rest of the info and connection points needed. Good luck!
07silverado
Member - Posts: 28
Posted: March 12, 2017 at 12:47 AM / IP Logged Link to Post Post Reply Quote 07silverado
So if you already have a truck with remote start on it factory you don't need any of the large gauge wires in the 10 pin connector?
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
