Setting up Viper 3305v for Door Poppers
seattle_ice
Member - Posts: 37
Posted: April 13, 2016 at 5:55 PM / IP Logged Link to Post Post Reply Quote seattle_ice
davep. wrote:
Ok. Now I understand. That will work. You don't need the 'upper' diodes on the relay coils. Just the ones between the module and the system. Unless you use the "momentary key=on" and "momentary off" switches you have in the first diagram. Then you DO need the upper diodes, or the momentary switches for the power latch will actuate the lock module.
Sounds like a cool project.
I removed the switches from the diagram for clarity, but they are there, so if they get used, I think those upper two diodes should stay.
Those two switches, plus two momentary push buttons to open the doors are there in case you don't have your remote, or the battery dies or something. The trunk also has the keyed lock so in case the battery goes dead, you can still get in to jump/charge it and open the doors/etc.
seattle_ice
Member - Posts: 37
Posted: April 13, 2016 at 6:03 PM / IP Logged Link to Post Post Reply Quote seattle_ice
If you are interested, this is (mostly) the wiring now. I did use small parts of the original harness for fitment and convenience, like the firewall bulkheads.
Setting up Viper 3305v for Door Poppers - Page 2 - Last Post -- posted image.
seattle_ice
Member - Posts: 37
Posted: April 18, 2016 at 6:46 PM / IP Logged Link to Post Post Reply Quote seattle_ice
Ok, here is my almost final setup. Any problems with this that are obvious?
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
