Ford Mondeo TDCi Wagon 2013/2014
tencap
Posted: June 03, 2016 at 9:10 PM / IP Logged Link to Post Post Reply Quote tencap
Hi just a request for alarm wiring for Aus RHD Ford Mondeo 2013/2014.
I've looked at the other Ford wiring in the install bay but none are applicable for the Mondeo.
Thanks in advance!!
tonanzith
Gold - Posts: 603
Posted: June 05, 2016 at 12:08 AM / IP Logged Link to Post Post Reply Quote tonanzith
Which is it 2013 or 14? And I will pull wiring. It SHOULD be the same or very similar to the ford fusion. My understanding is it is a fusion branded as a mondeo in certian countries.
Gary Sather
tencap
Posted: June 05, 2016 at 1:40 AM / IP Logged Link to Post Post Reply Quote tencap
Hello thanks! It's a 2013, I've looked at the Fusion wiring in the install bay and no colours match and there is no 26pin plug on the fuse/smart juction box.
Posted: June 05, 2016 at 2:33 AM / IP Logged Link to Post Post Reply Quote howie ll
Ford Euro software is a nightmare for DB-ALL2 don't even attempt a hard wire.
Posted: June 05, 2016 at 2:38 AM / IP Logged Link to Post Post Reply Quote howie ll
There's a DB-ALL 2 set up for the 13 model. 14 was the belated change-over to match the Fusion and Mazda 6, body and ELECTRICS completely different.
Go to a DEI dealer for the alarm and the DB-ALL 2, make sure the dealer flashes the DB-ALL 2 for you and supplies a wiring diagram.
Using a DB-ALL2 as W2W, i.e. connecting the dotted as well as the solid lines in the diagram can be done on the bench pre-installation it will save you hours!
And remember to connect the ignition wire,
Friday, October 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
