One diode for two window modules?
reelizmpro
Member - Posts: 14
Posted: June 09, 2016 at 12:13 AM / IP Logged Link to Post Post Reply Quote reelizmpro
I am in the middle of installing two 535T window modules on my convertible. My Omega K9 alarm has a starter kill on the orange wire (ground when armed). I spliced into the orange wire and diode isolated (band facing alarm) the new wire. My question is can I run this isolated wire to both modules OR do i have to further isolate the modules from each other? I figure it should be fine since they are just accessories and not sensors that activate the alarm. Thanks.
reelizmpro
Member - Posts: 14
Posted: June 10, 2016 at 6:19 PM / IP Logged Link to Post Post Reply Quote reelizmpro
Welp I figured it couldn't hurt to diode isolate everything so I went ahead and isolated the starter kill relay and the two 535T's with the stripes going toward the alarm.
I have a major problem...
The one touch UP/DOWN works perfectly but when I arm my alarm the windows roll DOWN instead of UP. The windows vent UP instead of DOWN. I checked my wiring and the one touch works right so it's not the window wiring. Any ideas?
reelizmpro
Member - Posts: 14
Posted: June 11, 2016 at 4:17 PM / IP Logged Link to Post Post Reply Quote reelizmpro
Figured it out. I switched the GWA orange wire and the gray aux wire. Works perfectly now.
Tuesday, November 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
