If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
At the driver side I "kind of" got power to the motor.
When I press the driver side switch down (11.4V) but when I press the switch up I only get like 1.4V.
Can it really be the switch that causes the problem?
I've tried 1 aftermarket switch and 2 second hand switches with the same result.
I'm starting to think it is some kind of problem with the ground wires?
Independent of the maybe faulty switch on the driver side, why wont it work on the passenger side? The power is there! Are they paired in some way?
I hope you guys can give me some help, this is my last chance of getting this fixed.
Non of the Swedish car electricians will help me if I don't pay at least 600$ :/
Thanks from a Swedish dude with defuse language skills.
