Load resistor dimming
davidhaller
Member - Posts: 16
Posted: June 24, 2016 at 8:58 AM / IP Logged Link to Post Post Reply Quote davidhaller
Hello, I have a 12v 27w led flood light and I would like to dim it. Can I use a load resistor to dim it a 1/4 of the original power?
geepherder
Platinum - Posts: 3,668
Posted: June 24, 2016 at 5:22 PM / IP Logged Link to Post Post Reply Quote geepherder
You won't know unless you try. However, if it's an LED bulb, it probably won't work- they usually have a pretty flexible voltage range (like 6-24v) and you won't really be able to tell a difference in brightness. Did it come with any specs on the box, etc.?
If you have an identical light, maybe you could try wiring them in series and see if it meets your needs.
davidhaller
Member - Posts: 16
Posted: June 24, 2016 at 8:24 PM / IP Logged Link to Post Post Reply Quote davidhaller
It is 12v, 27w, and 2.25a.
geepherder
Posted: June 26, 2016 at 7:51 PM / IP Logged Link to Post Post Reply Quote geepherder
I don't think this will work, otherwise your light would have a voltage range listed somewhere.
Your best option to try would still be to connect another one in series. However, if you want to use a resistor, a little math gives you roughly 5 1/3 ohms. If you try a power resistor of roughly this amount, that would give you one quarter the power. If you choose to do this, I'd use a 10 watt rating or more, just to be safe- it will get hot!
davidhaller
Member - Posts: 16
Posted: June 27, 2016 at 9:30 AM / IP Logged Link to Post Post Reply Quote davidhaller
I do remember it was a 6-24v range.
lurch228
Silver - Posts: 1,338
Posted: July 15, 2016 at 1:44 AM / IP Logged Link to Post Post Reply Quote lurch228
If the led has active voltage regulation you cant dim it if the regulation shuts down at a set voltage ie 6 volts. As you would need to go below 6 volt to achieve any dimming in most cases. (2) 3v leds would need 6 volts and voltage regulation reduces voltage above 6 volts up to 24 volts down to 6 volts.
davidhaller
Member - Posts: 16
Posted: July 18, 2016 at 9:24 PM / IP Logged Link to Post Post Reply Quote davidhaller
Before, I have put a dimmer and it dimmed it significantly.
lurch228
Posted: July 19, 2016 at 1:57 AM / IP Logged Link to Post Post Reply Quote lurch228
It depends on the regulation design, if it has no low or a lower cut off then max operating voltage on the led side then yes you can dim to the lowest voltage of led threshold of operation or regulation.
shezza
Member - Posts: 42
Posted: August 06, 2016 at 9:16 AM / IP Logged Link to Post Post Reply Quote shezza
I have two high powered LEDs running through resistors on my car.
I found the value by buying a 100ohm potentiometer first and twisting the dial till I liked the brightness (if this light gets used while the vehicle is not running I would make sure the vehicle is off for the test as the extra 1.5 - 2.0v could throw everything out of whack). Then I used a multimeter (set to ohms) to find the value of resistance on the potentiometer. Even if you didn't own a multimeter... You could still buy all of those 3 things for 6 or so dollars off ebay. Too easy really!
Then you just have to make sure the resistor you buy is 3W rated +
Good luck
shezza
Member - Posts: 42
Posted: August 06, 2016 at 9:24 AM / IP Logged Link to Post Post Reply Quote shezza
Forgot to mention... From what I have read, the most legit way of dimming a led is with a Pulse Width Modulator. Another way to go if you don't want to mess around with the above mentioned stuff and would also like to have the functionality of a constantly adjustable light. Also cheap as chips on ebay... Not sure about the quality, but only one way to know!
I personally wanted to "set it and forget it", but each application is different, so up to you!
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
