2011 Dodge Charger Alarm/Remote Start Wiring
lurch228
Silver - Posts: 1,338
Posted: July 30, 2016 at 9:38 PM / IP Logged
MAKE : DODGE | MODEL : CHARGER | YEAR : 2011
12volts
      RED / yellow (40A)
      BCM above passenger kick, black 4 pin plug (B), pin 3
Starter      lt. blue/tan (for starter kill only)      +      BCM above passenger kick, black 24 pin plug (A), pin 19
Ignition      pink/white or WHITE/ pink (for ignition sense only)      +      BCM above passenger kick, black 48 pin plug (E), pin 27 or 31
Power Lock      PURPLE / lt. green (passenger door switch)      - 330 ohms      Passenger Door Module, black 10 pin plug, pin 4
Power Unlock      (same as power lock)      - 100 ohms
Lock Motor      lt. green      5 wire      BCM above passenger kick, white 48 pin plug (F), pin 2
Unlock Motor      tan/lt. green      5 wire      BCM above passenger kick, white 48 pin plug (F), pin 1
Disarm Defeat      PURPLE / lt. green      5 wire      BCM above passenger kick, white 48 pin plug (F), pin 3
Parking Lights+      WHITE/ dk. green (LF); WHITE/ lt. blue (RF)      +      BCM, black 24 pin plug (A), pin 4; white 24 pin plug (D), pin 3
Parking Lights-      WHITE/ brown (see Tech Doc 1082)      -1130 ohms      BCM above passenger kick, blue 24 pin plug (G), pin 20
Hazards      WHITE/ dk. blue      -      BCM above passenger kick, blue 24 pin plug (G), pin 21
Turn Signal(L)      WHITE/ lt. green or wht/org(F); WHITE/ dk. green (R)      +      BCM, white 24 pin plug (D), pin 14; black 48 pin plug (E), pin 3
Turn Signal(R)      WHITE/ tan (F); WHITE/ yellow (R)      +      BCM, black 24 pin plug (A), pin 13; white 48 pin plug (F), pin 42
Door Trigger      purple      -      BCM above passenger kick, white 48 pin plug (F), pin 25
Dome Supervision      yellow/purple      +      BCM above passenger kick, blue 24 pin plug (G), pin 14
Trunk/Hatch Pin      PURPLE / orange      -      BCM above passenger kick, white 48 pin plug (F), pin 26
Hood Pin      PURPLE / lt. blue      -      BCM above passenger kick, black 24 pin plug (A), pin 11
Trunk/Hatch Release      lt. green      -      BCM above passenger kick, blue 24 pin plug (G), pin 8
Power Sliding Door      N/A
Factory Alarm Arm      (arms on lock with door open)
Factory Alarm Disarm      (see disarm no unlock)
Disarm No Unlock      (proximity key and push-button)
Tachometer      NOT BROWN / white (V6) or brown (V8)      ac      any fuel injector
Horn Trigger      dk. GREEN / WHITE      +      BCM above passenger kick, black 24 pin plug (A), pin 23
Memory Seat 1      PURPLE / brown      - resistor      Driver Door Module, black 10 pin plug, pin 6
Memory Seat 2      (same as memory seat 1)      - resistor
Memory Seat 3      N/A      - resistor
* The logo is registered trade mark of Dodge Corporate
