Fiat Freemont Remote start
roakusfm
Copper - Posts: 71
Posted: August 12, 2016 at 6:34 PM / IP Logged Link to Post Post Reply Quote roakusfm
Hello friends, Can someone help me to find wiring diagram for Fiat Freemont year 2012. I hope i will get a help here. Thanks!!
Peace and Love
lurch228
Silver - Posts: 1,338
Posted: August 12, 2016 at 11:01 PM / IP Logged Link to Post Post Reply Quote lurch228
2011-2016 Dodge Journey crossover (a/k/a Fiat Freemont) is the answer to you question.
Still need to verify wires for proper operation
Dodge Journey 2011-
PART       COLOR      LOCATION
12 VOLT CONSTANT      RED (+)      @ BCM, LT.GRAY 4-PIN PLUG(C2), PIN 3, SEE NOTE #2
STARTER      LT.BLUE/TAN (+) for STARTER KILL ONLY!!      @ BCM, BLACK 24-PIN PLUG(C1), PIN 19, SEE NOTE #2
STARTER 2      PURPLE / LT.BLUE (?)      @ KEYLESS IGNITION NODE (START/STOP Button) BLACK 6-PIN PLUG, PIN 4
IGNITION 1      PINK/WHITE (+)      @ BCM, BLACK 48-PIN PLUG(C5), PIN 27, SEE NOTE #2
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY /HEATER BLOWER 1      N/A
ACCESSORY /HEATER BLOWER 2      N/A
KEYSENSE      N/A
PARKING LIGHTS ( - )      EHITE/BROWN (-) THRU a 1130 Ohm resistor, use a Relay to ISOLATE Switch      @ BCM, BLUE 24-PIN PLUG(C7), PIN 20, SEE NOTE #2
PARKING LIGHTS ( + )      SEE NOTE #3      @ BCM, SEE NOTE #2
POWER LOCK      PURLE/LT. GREEN (-) THRU a 330 Ohm Resistor will LOCK      @ BCM, BLACK 48-PIN PLUG(C6), PIN 23 (without One-Touch up Windows) SEE NOTE #2
POWER UNLOCK      using same wire, a (-) THRU a 100 Ohm Resistor will UNLOCK      DIAGRAM
DOOR TRIGGER      PURPLE (-)      @ BCM, BLACK 48-PIN PLUG(C6), PIN 25, SEE NOTE #2
DOMELIGHT SUPERVISION      YELLOW/PURPLE (+)      @ BCM, BLUE 24-PIN PLUG(C7), PIN 14 SEE NOTE #2
TRUNK RELEASE      N/A
SLIDING POWER DOOR      N/A
HORN      DK.GREEN / WHITE (+)      @ BCM, BLACK 24-PIN PLUG(C1), PIN 23, SEE NOTE #2
TACH      BROWN / YELLOW, BROWN / DK.BLUE, BROWN / LT.BLUE, BROWN / TAN, BROWN / ORANGE or BROWN / PURPLE (AC)      @ Any FUEL-INJECTOR, 2-PIN PLUG, PIN 2
WAIT TO START LIGHT      N/A
BRAKE      DK.GREEN / WHITE (+)      @ BCM, WHITE 24-PIN PLUG(C4), PIN 18, SEE NOTE #2
FACTORY ALARM DISARM      N/A
ANTI-THEFT      NO INFORMATION AT THIS TIME!! See NOTE #1
EXTRA INFORMATION
NOTE #1: There is NO INFORMATION on the ANTI-THEFT SYSTEM or an INTERFACE BYPASS MODULE for this vehicle AT THIS TIME!! NOTE #2: The BCM is located Behind the GLOVE BOX. NOTE #3: The LEFT FRONT Parkinglight wire is a WHITE/ BROWN (+) @ BCM, BLACK 24-PIN PLUG(C1) PIN 4, the RIGHT FRONT Parking light wire is a WHITE/ ORANGE (+) @ BCM, WHITE 24-PIN PLUG(C4) PIN 3, the LEFT REAR Parking light wire is a WHITE/ GRAY (+) @ BCM, BLACK 48-PIN PLUG(C6) PIN 32 and the RIGHT REAR Parking light wire is a WHITE/ ORANGE (+) @ BCM, BLACK 48-PIN PLUG(C5) PIN 4, when connecting use a relay for each to isolate.
lurch228
Posted: August 12, 2016 at 11:21 PM / IP Logged Link to Post Post Reply Quote lurch228
These will need to be verified to work with the FIAT Journey by the respective Manufactures!
Bypass Fortin Dodge Journey 2012 (with Push-to-Start) EVO-CHRT6 or EVO-ONE
Bypass Xpresskit Dodge Journey 2012 (with Smart Key) XK09, DBALL/2/PRO
Posted: August 14, 2016 at 7:29 AM / IP Logged Link to Post Post Reply Quote howie ll
Euro car Lurch!! Will probably need a key in box or key wrap if it's of European origin.
Posted: August 14, 2016 at 7:32 AM / IP Logged Link to Post Post Reply Quote howie ll
Forget my post. It looks like a US build, haven't needed key wrap etc. on Chrysler Jeeps sold in Europe so you should be OK with what Lurch suggested, DB-ALL2 works fine on Jeeps.
roakusfm
Copper - Posts: 71
Posted: August 14, 2016 at 2:42 PM / IP Logged Link to Post Post Reply Quote roakusfm
ok thanks for your help, I will give a feedback here later.
Peace and Love
lurch228
Posted: August 14, 2016 at 2:46 PM / IP Logged Link to Post Post Reply Quote lurch228
Fiat Freemont Remote start - Last Post -- posted image.
