03 Ford E150 van remote starter
hightechredneck
Member - Posts: 13
Posted: September 03, 2016 at 5:08 PM / IP Logged Link to Post Post Reply Quote hightechredneck
Hello,
I was looking for the lock relay wiring and possibly where the RPM signal can be picked up exactly?
Thanks!
lurch228
Silver - Posts: 1,338
Posted: September 03, 2016 at 6:12 PM / IP Logged Link to Post Post Reply Quote lurch228
2003 Ford (E150)Econoline Remote Starter Wiring Guide
Vehicle Battery Positive Wire (+): Yellow
Vehicle Battery Positive Wire Location: Ignition Switch Harness
Vehicle Ignition Wire (+): RED / Light Green
Vehicle Ignition Wire Location: Ignition Switch Harness
Vehicle Second Ignition Wire (+): BLACK/ Light Green
Vehicle Second Ignition Wire Location: Ignition Switch Harness
Vehicle Accessory Wire (+): Gray / YELLOW
Vehicle Accessory Wire Location: Ignition Switch Harness
Vehicle Second Accessory Wire (+): N/A
Vehicle Second Accessory Wire Location: N/A
Automobile Engine Starter Wire (+): WHITE/ Pink
Automobile Engine Starter Wire Location: Ignition Switch Harness
Automobile Second Engine Starter Wire (-): N/A
Automobile Second Engine Starter Wire Location: N/A
Factory Anti-Theft System: None
Factory Anti-Theft System Type: None
Car Key Sense Wire (-): BLACK/ Pink
Car Key Sense Wire Location: Steering Column Harness
Car Neutral Safety Wire (+): N/A
Car Neutral Safety Wire Location: N/A
Car Tachometer Wire (-): WHITE/ Pink
Car Tachometer Wire Location: At PCM Module at Rear of the Engine on Driver Side
Car Speed Sense Wire: Gray/Black
Car Speed Sense Wire Location: Pin #58 in 104 Pin Plug at PCM Module at Rear of the Engine on Driver Side
Car Parking Lights Wire (+): Brown
Car Parking Lights Wire Location: At Vehicle Light Switch
Car Brake Lights Wire (+): Light Green
Car Brake Lights Wire Location: At Brake Switch Above the Pedal
Car Reverse Lights Wire (+): BLACK/ Pink
Car Reverse Lights Wire Location: At Light Bulb Socket
Car Horn Wire (-): Dark Blue
Car Horn Wire Location: At Steering Column
2003 Ford (E150)Econoline Car Alarm Wiring Color Codes
Battery Constant 12v+ Positive Wire (+): Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): WHITE/ Pink
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): RED / Green
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): BLACK/ Green
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Gray / YELLOW
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Brown
Parking Light Positive Wire Location: In Drivers Kick Panel, Harness To Rear Of Vehicle
Power Door Lock Negative Wire (-): Red (5 Wire Reverse Polarity). If vehicle has a factory keyless entry, pink / YELLOW is lock, and pink/light green is unlock, it is a negative (-) door locking system, if vehicle is without a factory keyless it is a 5 wire reverse polarity system and you must test from the passengers lock/unlock switch this switch is the master switch.
Power Door Lock Negative Wire Location: In Either Kick Panel
Power Door Unlock Negative Wire (-): Brown (5 Wire Reverse Polarity). If vehicle has a factory keyless entry, pink / YELLOW is lock, and pink/light green is unlock, it is a negative (-) door locking system, if vehicle is without a factory keyless it is a 5 wire reverse polarity system and you must test from the passengers lock/unlock switch this switch is the master switch.
Power Door Unlock Negative Wire Location: In Either Kick Panel
Door Trigger Positive Wire (+): BLACK/ Light Blue
Door Trigger Positive Wire Location: At Pin Switch Or Courtesy Light
Domelight Supervision Wire: Use Door Trigger (Requires Relay)
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Dark Blue
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): WHITE/ Pink
Tachometer Wire Negative Wire Location: At CTO Test Connector. The CTO test connector is located all by itself, it is labled “CTO” test above the brake booster on the drivers side of engine compartment.
Brake Light Positive Wire (+): Green
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Dark GREEN/ Purple
Factory Alarm Disarm Wire Location: At Anti-Theft Module. The anti-theft module is located behind the driver’s side “B” pillar.
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
hightechredneck
Member - Posts: 13
Posted: September 04, 2016 at 3:17 PM / IP Logged Link to Post Post Reply Quote hightechredneck
Thanks brother!
lurch228
Posted: September 04, 2016 at 4:47 PM / IP Logged Link to Post Post Reply Quote lurch228
You got it!
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
