Pairing DEI 516U with the 508D
prince504
Copper - Posts: 108
Posted: September 14, 2016 at 9:36 AM / IP Logged Link to Post Post Reply Quote prince504
looking to pair a DEI 516U and a 508D proximity sensor with a 3rd party alarm. Door lock/unlock, trunk release or any other functions of the alarm isn't desired. Simply want to get a notification on the 2-way remote if someone intrudes in the vehicle and for the viper module to warn off intruders.
I have read on other threads that the 508D can be thrown off based on weather conditions. I was considering wiring the warn away trigger of the 508D to trigger the voice module and wiring the full trigger to the instant trigger of the alarm (hence notifying the fob)
Any idea where to mount the proximity sensor?
lurch228
Silver - Posts: 1,338
Posted: September 14, 2016 at 3:44 PM / IP Logged Link to Post Post Reply Quote lurch228
For best results as close to center of vehicle as possible and as high as possible while staying below the bottom of window opening usually works the best in my experience. If you have a center console us double sided tape or hook side of adhesive back velcro to attach to carpet on floor hump/channel.
prince504
Copper - Posts: 108
Posted: September 14, 2016 at 5:57 PM / IP Logged Link to Post Post Reply Quote prince504
have you ever found the need to mount a metal plate beneath the motion sensor? And would mounting it beneath the car seats (driver side), close to the middle be a good spot?
The vehicle is a 2006 BMW 650i convertible and attempting to take out the center console would suck
Thnx
lurch228
Posted: September 14, 2016 at 8:03 PM / IP Logged Link to Post Post Reply Quote lurch228
If the center console has a storage compartment you can usually remove the bin to get access to place the sensor. Or just remove the top of the console at most.
prince504
Copper - Posts: 108
Posted: September 14, 2016 at 8:43 PM / IP Logged Link to Post Post Reply Quote prince504
Thnx for the advice... You are like th only one (or one of the extreme few) that help ppl in this forum these days..
Much appreciated.
lurch228
Posted: September 14, 2016 at 9:59 PM / IP Logged Link to Post Post Reply Quote lurch228
No problem! Some day you can pay it foward!
