2006 expedition heated mirrors
mlmaher
Posted: September 15, 2016 at 8:08 AM / IP Logged Link to Post Post Reply Quote mlmaher
I'm looking for wiring information on 2006 ford expedition so that I can add heated mirrors. Does anyone have information for that specific year? Thank You
lurch228
Silver - Posts: 1,338
Posted: September 15, 2016 at 1:37 PM / IP Logged Link to Post Post Reply Quote lurch228
See if this helps!
06 Heated Mirrors.pdf
If heated mirrors were offered on your truck, you just need to plug in the new mirrors.
If the wires aren't there already if you have rear defrost. You will have to run 16 awg wire from 10-amp fuse #8 to each mirror, plus the ground wire of course. See the attached PDF for how it's supposed to be wired.
If you have 99-04 when heated mirrors were not offered you will need to make a new connection for the heat feature. You can just wire it to an "accessory on" wire, as that is how Ford has it wired.
mlmaher
Posted: September 15, 2016 at 5:18 PM / IP Logged Link to Post Post Reply Quote mlmaher
The connector from the mirror has 4 wires two for the mirror motor and two for the puddle lamp. However the other side of the connector has several wires on it that aren't connected to anything on the mirror side. Any chance for a diagram that shows what those wires would go to?
lurch228
Posted: September 16, 2016 at 4:21 PM / IP Logged Link to Post Post Reply Quote lurch228
Use a DMM set to DC with 1 probe to ground and test the unconnected wires for (+) feeds, and DMM set to continuity for grounds, to determine there function as they will be the options you original mirrors didn't have like blinker and heated mirrors. If the new mirrors have the same plug then it will be plug and play.
mlmaher
Posted: September 18, 2016 at 10:34 PM / IP Logged Link to Post Post Reply Quote mlmaher
That thought helped sort it out. The option was available in 2006 I just didn't have a model it was installed on. Thought perhaps the wiring was in the harness and it was. Verified pin 1 was hot when the rear defrost turned on and went to zero when it was off. Also verified that pin 9 was the ground. Thanks again I'm on my way to wrapping up this project!
lurch228
Posted: September 19, 2016 at 6:55 AM / IP Logged Link to Post Post Reply Quote lurch228
IF you would like to help the next person please post the wire colors and functions for the mirrors.
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
