2 way remote not show lock icon.
kulblue
Copper - Posts: 74
Posted: October 06, 2016 at 4:53 AM / IP Logged Link to Post Post Reply Quote kulblue
I just programmed my avital 447L to my Python 513. Everything works fine . If I press lock/unlock, the car locks/unlocks. On the avital 2 way remote screen the icon didn't change to lock stay on unlock icon. If I remote start didn't show the mins too. Pls! Help me. Thanks
lurch228
Silver - Posts: 1,338
Posted: October 07, 2016 at 9:07 AM / IP Logged Link to Post Post Reply Quote lurch228
If you didn't replace the 1 way antenna that came with your Python 513 with the 2 way antenna then it won't be able to send back to the 447L.
You will need to replace the 3 wire antenna wire with a 4 wire and the antenna will need to be a 2 way antenna the DEI 544N.
Which is what ships with the 5303 System that the 477L also (not just the 447L) comes with.
kulblue
Copper - Posts: 74
Posted: October 07, 2016 at 11:00 PM / IP Logged Link to Post Post Reply Quote kulblue
Oh Ok Thanks
lurch228
Posted: October 07, 2016 at 11:38 PM / IP Logged Link to Post Post Reply Quote lurch228
EBay is you friend for the antenna and antenna wire together.
kulblue
Copper - Posts: 74
Posted: October 08, 2016 at 10:06 AM / IP Logged Link to Post Post Reply Quote kulblue
The Avital 4308L can use the antenna and remote? I seen on eBay but not sure if same parts # of the python 5303P antenna
lurch228
Posted: October 08, 2016 at 7:57 PM / IP Logged Link to Post Post Reply Quote lurch228
DEI is Avital, Viper, Python, Clifford, AUTOSTART, Automate, and AstroStart the latter brands mostly in Canada.
Typically the letter at the end is a Brand designation of a given model especially in the newer units. Any one way brain is the same it's counterpart 2-way brain.
All IVU antennas are required to be FCC licensed in the US so if a 2 way system has the same companion remote as a 1 way then it will work.
You can do some more research here: http://www.drdetailshop.com/ANTENNAS.htm
http://www.drdetailshop.com/A544N.htm
And here is the Avital 4308L Link:http://www.drdetailshop.com/avital4308.htm
On this page if you hover your mouse over the blue "Remote" it will show the link at the bottom of the page with the part number of the remote.
Then cross any system that uses that 1 way companion remote 474L/V/P/X to a match with a 2 way remote Here:http://www.drdetailshop.com/transcross.htm
Just be aware that there are antennas with the valet and LED and those with out. You can substitute a valet led but will need the early antenna cable that has separate valet and LED plugs at the brain side.
lurch228
Posted: October 08, 2016 at 9:31 PM / IP Logged Link to Post Post Reply Quote lurch228
Also the 7143L is the replacement for the following:
Des. 340,000
CE0890
800-274-0200
FCC ID: EZSDEI470
FCC ID: EZSDEI471
FCC ID: EZSDEI474
FCC ID: EZSDEI475
FCC ID: EZSDEI476
FCC ID: EZSDEI485
FCC ID: EZSDEI7143
If a system uses the 7143L it is also compatible with the 474L/V/P/T
kulblue
Copper - Posts: 74
Posted: October 09, 2016 at 1:07 AM / IP Logged Link to Post Post Reply Quote kulblue
Nice. Thanks for the help.
Check PM I sent msg.
lurch228
Posted: October 09, 2016 at 5:51 PM / IP Logged Link to Post Post Reply Quote lurch228
Okay
