'96 Jeep Grand Cherokee 4.0L Autogas
chris130
Member - Posts: 6
Posted: October 06, 2016 at 12:49 PM / IP Logged Link to Post Post Reply Quote chris130
96' Jeep Grand Cherokee 4.0L Limited edition 6cylinders
Need to find
a) rpm (tacho) signal wire
b) ignition +12V wire
from coil/distributor wires
lurch228
Silver - Posts: 1,338
Posted: October 06, 2016 at 1:35 PM / IP Logged Link to Post Post Reply Quote lurch228
Tach Gray/White @ Coil
Ignition Dark Blue/Gray Ignition Switch Harness
Ignition 2 RED / Black Ignition Switch Harness (for AC)
chris130
Member - Posts: 6
Posted: October 09, 2016 at 6:04 AM / IP Logged Link to Post Post Reply Quote chris130
I found this on the net.
We have a 3 wire-tail connected to the distributor
according to this diagram:
a)5 volt supply
b)camshaft position sensor signal
c)ground signal
from which one could i take the rpm signal? Could i identify it with a multimeter?
'96 Jeep Grand Cherokee 4.0L Autogas - Last Post -- posted image.
lurch228
Posted: October 09, 2016 at 9:21 AM / IP Logged Link to Post Post Reply Quote lurch228
You need a signal wire, the listing says Dark Blue/ Gray and your diagram says Gray and Black which is the signal. Either signal will work from your diagram just make sure it's protected from the elements once connected.
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
