QX4 and Pathfinder?
carguy411
Silver - Posts: 683
Posted: May 29, 2003 at 11:40 PM / IP Logged
ok a friend of mine hass a 2001 Infity QX4
now its just like the pathfinder bt do u know if the pathfinder steath JLaudio enclosure would fit????
also h wants to add a amp to the factry system with BOSE
now in my book i have the PAC interface thats for the Nissans with the BOSE will that work
or just use the high low converter i want to get the best sound quality avalible
thanks
esmith69
Gold - Posts: 1,511
Posted: May 30, 2003 at 1:42 PM / IP Logged
I'm guessing the amplifier is intended to be used with the JL sub?  In that case as long as you're not replacing the stock bose head unit, you just need to get a good line out converter and tap in to the amplified speaker leads for the rear speakers.  Verify the polarity of the speaker wiring using a DMM, before you make the final connections to the converter.
Those PAC interfaces are really only for adapting an aftermarket head unit so that it will send a compatible signal to the bose amplifiers.
I clicked on the link that goes to the installation manual for the 96-99 model, and at the very top it says for pathfinder and Qx4.  So I'm guessing for the 01 vehicles it's gonna be the same thing, but you might wanna double check the photos on their site to make sure it looks like it'll fit.  Or if you're still in doubt try emailing JL directly.
Ethan
Donate to the12volt.com
carguy411
Silver - Posts: 683
Posted: May 30, 2003 at 2:23 PM / IP Logged
ok thanks so just get a normal line out converter i dont need the PAC
thanks
