2007 Kia Optima Wiring
dalepre
Member - Posts: 9
Posted: November 09, 2016 at 4:34 AM / IP Logged Link to Post Post Reply Quote dalepre
Does anyone have the Remote Start/Alarm, Audio and Cruise Control info for a 2007 Kia Optima?
I was able to get part of the system in by using another year model but having issues with the cruise control.
Thanks In Advance,
Dale
Dale Prevette
wirewise
Moderator - Posts: 489
Posted: January 08, 2017 at 6:46 AM / IP Logged Link to Post Post Reply Quote wirewise
12 VOLT CONSTANT      (1)PINK (+) and (1)ORANGE (+)      @ IGNITION SWITCH HARNESS
STARTER      GREEN (+)      @ IGNITION SWITCH HARNESS
STARTER 2      N/A
IGNITION 1      GREEN (+)      @ IGNITION SWITCH HARNESS
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY /HEATER BLOWER 1      BLACK (+)      @ IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2      RED (+)      @ IGNITION SWITCH HARNESS
KEYSENSE      N/A
PARKING LIGHTS ( - )      YELLOW/BLACK (-)      @ HEADLIGHT Switch or BCM, 20-Pin Plug, Pin 4, See NOTE *1
PARKING LIGHTS ( + )      GRAY (+) Left and GRAY (+) Right, use both! See NOTE *2      @ FUSEBOX, REAR BROWN 12-Pin Plug, Pins 2 and 8
POWER LOCK      PINK/BLACK (TYPE B)      @ DRIVERS KICK PANEL or BCM, 20-Pin Plug, Pin 3, See NOTE *1
POWER UNLOCK      BROWN (TYPE B)      @ DRIVERS KICK PANEL or BCM, 20-Pin Plug, Pin 11, See NOTE *1
LOCK MOTOR WIRE      PINK/BLACK (5-WIRE TYPE)      in DRIVERS KICK PANEL @ DOOR HARNESS
DOOR TRIGGER      YELLOW/ORANGE (-)      @ BCM, 24-Pin Plug, Pin 22, See NOTE *1
DOMELIGHT SUPERVISION      BLUE (-)      in DRIVERS KICK PANEL or @ BCM, 16-Pin Plug, Pin 1, See NOTE *1
TRUNK RELEASE      WHITE/ BLACK (-) Requires Relay Part #775      in DRIVERS KICK PANEL or @ BCM, 20-Pin Plug, Pin 13, See NOTE *1
SLIDING POWER DOOR      N/A
HORN      WHITE (-) Requires Relay Part #775      @ HORN Switch or in DRIVERS KICK PANEL
TACH      YELLOW/BLACK (AC)      in DRIVERS KICK PANEL, GRAY 33-Pin Plug, Pin 5
WAIT TO START LIGHT      N/A
BRAKE      Wire turns from BROWN to RED (+)      @ SWITCH above BRAKE PEDAL or in DRIVERS KICK PANEL
FACTORY ALARM DISARM      ORANGE (-) See NOTE *3      in DRIVERS KICK PANEL or BCM, 20-Pin Plug, Pin 2, See NOTE *1
ANTI-THEFT      KIA's TRANSPONDER ANTI-THEFT System, See NOTE #4      @ IGNITION SWITCH TUMBLER
NOTES
NOTE *1 The BCM (Body Control Module) is located to the LEFT of the STEERING COLUMN.
NOTE *2 The (+) Positive Parking Light circuit on this vehicle requires connecting to (2) wires, this connection will require (2) Extra relays to connect
NOTE *3 Testing of this wire must be done while Turning the Key in the Drivers Door Key Cylinder.
NOTE #4: This vehicle May Be Equipped with KIA'S TRANSPONDER ANTI-THEFT SYSTEM,
~wirewise~
