2012 Hyundai Santa Fe Standard Key Wiring
sparky215
Posted: November 27, 2016 at 10:27 PM / IP Logged Link to Post Post Reply Quote sparky215
Hi all,
I'm looking for the wiring diagram for a 2012 Hyundai Santa Fe standard key for remote start/keyless entry. I saw one for a 2010 and one for the 2013. I'm not sure if the 2012 is the same as one of those. Thanks for your help.
wirewise
Moderator - Posts: 489
Posted: January 08, 2017 at 6:54 AM / IP Logged Link to Post Post Reply Quote wirewise
The 2010 through 2012 standard key are the same.
SANTA FE      2010-2012
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      RED (+) 40 AMP      @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 5
STARTER      GREEN (+)      @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 1
STARTER 2      N/A
IGNITION 1      ORANGE (+)      @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 6
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY /HEATER BLOWER 1      BLUE (+)      @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 3
ACCESSORY /HEATER BLOWER 2      YELLOW (+)      @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 4
KEYSENSE      YELLOW (+)      @ IGNITION KEY SWITCH, WHITE 6-PIN PLUG, PIN 3
PARKING LIGHTS ( - )      BLUE/ORANGE (-)      @ HEADLIGHT SWITCH, (WHITE, 18-PIN PLUG), PIN 14
PARKING LIGHTS ( + )      GREEN(+)(Left) and YELLOW(+)(Right) use both!      @ DASH FUSE BOX, (GRAY, 18-PIN PLUG(D), PINS 3 and 4
POWER LOCK      BLUE/BLACK (-) TYPE B, SEE NOTE #3      @ DRIVERS KICK PANEL, (BROWN, 24-PIN PLUG), PIN 18
POWER UNLOCK      GRAY/BLACK (-) TYPE B, SEE NOTE #3      @ DRIVERS KICK PANEL, (BROWN, 24-PIN PLUG), PIN 19
LOCK MOTOR WIRE      ORANGE (5-WIRE)      @ DASH FUSE BOX, (GRAY, 18-PIN PLUG(D), PIN 18
DOOR TRIGGER      ORANGE (-)      @ DRIVERS KICK PANEL, (BROWN, 24-PIN PLUG), PIN 12
DOMELIGHT SUPERVISION      BROWN (-)      @ DASH FUSE BOX, (RED, 16-PIN PLUG(B), PIN 1
TRUNK RELEASE      UNLOCKS with Doors
SLIDING POWER DOOR      N/A
HORN      GRAY/BLACK (-)      @ DRIVERS KICK PANEL, (GREEN, 24-PIN PLUG), PIN 20
TACH      Any wire NOT ORANGE (AC)      @ Any FUEL-INJECTOR
WAIT TO START LIGHT      N/A
BRAKE      NOTE #4      @ BRAKE PEDAL SWITCH, (WHITE, 4-PIN PLUG), PIN 1
FACTORY ALARM DISARM      PINK and GRAY (-), Requires Double Pulse, NOTE #3      @ DRIVERS KICK PANEL, (BROWN, 24-PIN PLUG), PINS 6 and 4
ANTI-THEFT      HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1      @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: This vehicle May Be Equipped with HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM,
~wirewise~
palmeruf
Posted: November 23, 2017 at 9:46 AM / IP Logged Link to Post Post Reply Quote palmeruf
I'm trying to wire a boyo a-pass touch, a keypad to unlock the car. I see on the above post the power lock and power unlock wires. Is there a signal lock and signal unlock? These are the wires the directions call out. First attempt to install anything aftermarket beyond a stereo or accessory lights.
Thanks,
Mat
Mat
