If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
With the harness attached.
and the pair of relays tapped into the van wiring.
This relay is part of the alarm harness, I believe.
the relay info...
and the way it's wired.
This is the other 2 relays that were tapped into existing wires..
and how they were wired.
All this was tucked into the cavity in the drivers side footwell, and covered by the kick panel.
