Viper 4704, 2005 Dodge Ram 1500 Daytona
okaytay
Posted: December 19, 2016 at 1:31 PM / IP Logged Link to Post Post Reply Quote okaytay
I have a 2005 Dodge Ram 1500 Daytona
I bought this truck used with what i believe is a Viper 4704 system installed.
I took a peek under the dash and saw a 4x04 brain under the dash and i have a 7752v remote that controls it.
My problem i have is when i remote start the interior fan for heat or the radio does not come on.
From the research i have done it could be wired improperly (the Ignition2 wire)
OR
it could be that the remote needs to be programmed to accessory 2?
Right now it is -37 with the windchill so i havent looked to see if they have wired the ignition 2 wire improperly
Any thoughts????
smokeman1
Platinum - Posts: 1,589
Posted: December 19, 2016 at 2:14 PM / IP Logged Link to Post Post Reply Quote smokeman1
The remote does not get programmed to an Accessory 2.
Could be a blown fuse, not connected,(orange heavy gauge wire from the viper), loose connection at accessory wire, not connected properly.
Since it is not known if it worked properly to begin with, you will have to test/check the connections with a DMM for function.
Wire listings show 1, starter, 2 ignition wires and 1 accessory with a caveat.
Please read note 8 of the Bulldog wiring and see if it applies to your truck.
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
Where are you that it is -37 wind chill?
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
