2006 Volvo XC90 Alarm/Remote Start Wiring
1klw
Member - Posts: 22
Posted: January 02, 2017 at 1:12 PM / IP Logged
im looking for a wiring diagram for a volvo xc90 and i will be using a alcan module.thanks
wirewise
Moderator - Posts: 489
Posted: January 08, 2017 at 7:15 AM / IP Logged
XC90      2005-2014
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      VOLVO'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      RED (+) (X2) 50 AMP Each      in DRIVERS KICK PANEL, HARNESS to REAR of Vehicle or CEM, NOTE #2
STARTER      YELLOW/WHITE (+)      @ IGNITION SWITCH, (8-PIN PLUG), PIN 7
STARTER 2      N/A
IGNITION 1      BLUE/RED (+)      @ IGNITION SWITCH, (8-PIN PLUG), PIN 1
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY /HEATER BLOWER 1      BLUE (+)      @ IGNITION SWITCH, (8-PIN PLUG), PIN 8
ACCESSORY /HEATER BLOWER 2      PURPLE (+)      @ IGNITION SWITCH, (8-PIN PLUG), PIN 6
KEYSENSE      YELLOW (+) Required!      @ IGNITION SWITCH, (8-PIN PLUG), PIN 3
PARKING LIGHTS ( - )      USE HAZARDS YELLOW (-)      hazard switch, 5 pin plug, pin 3
PARKING LIGHTS ( + )      WHITE(+)(Left Front) and GRAY(+)(Right Front) use both, NOTE #3      @ CEM, (TOP REAR, 36-PIN PLUG), PINS 19 and 20, NOTE #2
POWER LOCK      PURPLE / WHITE (-), TYPE B, NOTE #6      @ DDM, (GREEN, 30-PIN PLUG), PIN 13, NOTE #4
POWER UNLOCK      BLUE/WHITE (-), TYPE B, NOTE #8      @ DDM, (GREEN, 30-PIN PLUG), PIN 12, NOTE #4
LOCK MOTOR WIRE      YELLOW (+), 5-Wire Type      @ REM, (BLACK, 32-PIN PLUG), PIN 23, NOTE #5
DOOR TRIGGER      PINK (-)      @ REM, (REAR, 14-PIN PLUG), PIN 12, NOTE #5
DOMELIGHT SUPERVISION      WHITE (-)      @ UNDERDASH LIGHT
TRUNK RELEASE      N/A
SLIDING POWER DOOR      N/A
HORN      YELLOW (-)      @ STEERING WHEEL MODULE, (GREEN, 10-PIN PLUG), PIN 10
TACH      Any wire NOT GREEN (AC)      @ Any FUEL-INJECTOR
WAIT TO START LIGHT      N/A
BRAKE      YELLOW/RED (+)      @ BRAKE PEDAL SWITCH
FACTORY ALARM DISARM      DISARMS with UNLOCK
ANTI-THEFT      VOLVO'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1      @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: VOLVO'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part #791 Bypass Module for REMOTE START, (Requires Extra Key)
NOTE #2: the CEM, (Central Electronic Module) is located Under the DRIVERS DASH.
NOTE #3: the LEFT REAR Parking Light wire is a GRAYWHITE(+), at the REM, (36-PIN PLUG) PIN 6 and the RIGHT REAR Parking Light is a WHITE/ ORANGE(+) at the REM, (36-PIN PLUG) PIN 5, use ALL wires and Relay Isolate.
NOTE #4: the DDM, (Drivers Door Module), is located in the DRIVERS DOOR.
NOTE #5: the REM, (Rear Electronic Module) is located on the LEFT side of the CARGO COMPARTMENT.
NOTE #6: this wire will also LOCK and ARM the FACTORY ALARM. TEST this wire wile Turning the KEY in the DRIVERS DOOR.
NOTE #7: this wire will Require a DOUBLE PULSE to UNLOCK and DISARM the FACTORY ALARM. TEST this wire wile Turning the KEY in the DRIVERS DOOR.
~wirewise~ Verify all wiring with your meter before making any connections!
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
