Small Automotive Relay?
astuff
Member - Posts: 7
Posted: January 07, 2017 at 8:16 PM / IP Logged Link to Post Post Reply Quote astuff
I am looking for a 12v relay to use in an automotive application but the standard cube and socket is a bit too big for where I want to put it. Is there another series of automotive relays out there that still has a plug and socket but are a bit smaller?
I really don't want to solder leads to a PC board relay but that is the only thing I have seen so far.
Maximum switching load would be 2 amps. SPST is all that is needed.
Thanks in advance for any suggestions.
geepherder
Platinum - Posts: 3,668
Posted: January 08, 2017 at 8:46 AM / IP Logged Link to Post Post Reply Quote geepherder
Maybe something like this would work for you:
http://www.jegs.com/i/Painless/764/80136/10002/-1?CAWELAID=1710509887&CAGPSPN=pla&CAAGID=15769068431&CATCI=pla-177200846231&gclid=CI7c2YnjstECFQmewAodoggCNw
This is just an example. These relays are commonly used for horns and sometimes fuel pumps. Maybe your local parts store has them. If you don't want to crimp pins you can try something like this:
https://www.aliexpress.com/item/DIY-Car-Motor-12V-12-Volt-30A-AMP-Duty-Relay-Harness-Socket-5Pin-5-Wire-Sales/32547043339.html?spm=2114.01010208.3.28.WyqTQ8&ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_10000009_10084_10083_10080_10082_10081_10060_10062_10056_503_10055_10054_10059_10099_501_10078_10079_10000012_426_10103_10073_10102_10000015_10096_10052_10053_10050_10107_10051_10106,searchweb201603_3,afswitch_5,single_sort_0_default&btsid=203efc7d-3c2e-40cb-b918-7b2ae9c4acbb
astuff
Member - Posts: 7
Posted: January 08, 2017 at 10:39 PM / IP Logged Link to Post Post Reply Quote astuff
Thanks for the info. Those do look a bit thinner but I don't see any specs. The sockets shown have sliding/daisy chain connectors - may trim them down so not to be wider than the relay itself.
Off to the parts stores tomorrow to see what they have in stock.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
