97 jeep Cherokee 5706 wiring
130eng
Posted: January 09, 2017 at 7:09 AM / IP Logged Link to Post Post Reply Quote 130eng
Hello guys and gals. I was hoping I could get some backup on wiring in my sons 5706v remote start and security system in his jeep. I've highlighted the wires I think I need but was hoping someone with some more experience could look them over for me to be sure. Before my son and I embark on this project. Thank you in advance and have a great day97 jeep Cherokee 5706 wiring - Last Post -- posted image.
130eng
Posted: January 09, 2017 at 11:59 AM / IP Logged Link to Post Post Reply Quote 130eng
If this is the wrong location for this post please let me know.
kaezoo
Copper - Posts: 125
Posted: January 10, 2017 at 6:18 AM / IP Logged Link to Post Post Reply Quote kaezoo
I'm not entirely sure what you're asking for, but you might be confused about the functions of the "heavy gauge" wires on the 10-pin harness. The red, RED / white and RED / black wires are the power source for the ignition, accessory, starter and flex relays. All three wires must be connected to your 12-volt power source. The red wire supplies the power for the pink ignition output; the RED / black supplies the power for the violet starter output and the orange accessory output, and the RED / white supplies the power for the pink/white flex relay output (which you'll be using for the vehicle's Accessory 2 circuit). You didn't highlight the GREEN/ violet starter wire pair, the pink/white flex relay output, or the pink ignition output, so I suspect you were thinking of the red and RED / stripe wires as outputs rather than inputs.
Wiring up the lock/unlock system in this vehicle will not be simple. Unless you can find a data module to handle lock/unlock for you, you'll need to install a pair of relays in both front doors. A Directed 455T module would make the installation much easier, but it's been discontinued for years and won't be easy to find.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
