2002 Dakota, RS, fan does not blow hot air
blk97ta
Posted: January 13, 2017 at 5:42 PM / IP Logged Link to Post Post Reply Quote blk97ta
I have a 2002 dakota . I wired up a compustar cm-800 module. Everything works as it should except the fan does not blow the hot air . Any ideas ? Do i need to wire a relay up for the blower ?
smokeman1
Platinum - Posts: 1,589
Posted: January 13, 2017 at 9:05 PM / IP Logged Link to Post Post Reply Quote smokeman1
There are two Accessory wires listed. Are both connected?
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
blk97ta
Posted: January 13, 2017 at 9:46 PM / IP Logged Link to Post Post Reply Quote blk97ta
The wiring diagram for 2002 says 1 ? But 2003 says 2 accessory wires (currently the BLACK/ white wire isn't hooked up ) can I use the blue wire (selectable by jumper ? ) to power the 2nd accessory wire ?
smokeman1
Posted: January 14, 2017 at 6:46 AM / IP Logged Link to Post Post Reply Quote smokeman1
Yes.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
