2011 Kia Forte, command start
thefatpigeon
Member - Posts: 15
Posted: January 28, 2017 at 4:18 PM / IP Logged Link to Post Post Reply Quote thefatpigeon
Something is causeing my starter to stop cranking. it will only crank for a second and then cut out.   I then get confirmation from the remote that the car is started.
thefatpigeon
Member - Posts: 15
Posted: January 28, 2017 at 7:46 PM / IP Logged Link to Post Post Reply Quote thefatpigeon
This has got to be a DBALL 2 issue. I attempted to reflash the DBALL. It will not learn my transponder. This is a canadian Kia. Also when The key is in the on position I have a car indicator with a key in it. This symbol means I have a transponder.
thefatpigeon
Member - Posts: 15
Posted: February 07, 2017 at 8:52 PM / IP Logged Link to Post Post Reply Quote thefatpigeon
Kia forte 2011.
DBALL 2 will not learn transponder key. car starts with key. will not start with remote starter.
follow the steps to learn the key. It flashes LED code for learning.( in instructructions it says will take 4-6 minutes) after a minute of this is stops and flashes code for "programmed succussfully no BYPASS"
I am having issues with the remote starter and I want to make sure its not the DBALL that is giving me the issues.
Regards
silvercivicsir
Copper - Posts: 416
Posted: February 08, 2017 at 4:14 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
I had no luck using a DBALL for a Kia/Hyundia. Idatalink learned right away. I would suggest switching bypass modules and using a Idatalink.
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
