Compustar & Rockford Fosgate Autolink GPS
natsys
Copper - Posts: 87
Posted: February 09, 2017 at 9:31 AM / IP Logged Link to Post Post Reply Quote natsys
Looks like I stumped the class with a request for a 2011 Hino 258 wiring diagram--lots of looks but no posts.
I'm going to go ahead with mine. It doesn't require a bypass so I should be able to determine all the correct wires from the ign switch. I'll take a few pics and post back just in case anyone else comes this way. I have seen videos of them done online, but no details.
In the meantime...trying to make sure before I leap if a Rockford Fosgate Autolink GPS Tracker will work with my intended FT7000-AS CONT. The compatibility sheet says it will work with the CM6200 and CM7200 so I think it should work with the newer model. However, it also says a Blade-AL must be used "for full connectivity with remote starter functions". Since no bypass is required (takes plain steel keys) am I correct that in this case it won't be needed? Does this unit do something else that I've missed that would be required? It's hard to find information on it since no application for a Hino exists. Of course, if Hino's don't require on then it rightfully shouldn't exist.
So, can any of the Compustar vets help out? Thanks.
