2015 Rav4 Toyota Immobilizer cable
josipeiro
Posted: February 24, 2017 at 4:44 PM / IP Logged Link to Post Post Reply Quote josipeiro
Hi, i'm installing a gps to the suv, the gps got a Immobilizer function, is the same that the alarm, but the truck have no switch key, is push-button ignition, so i try to find the cable to what i need to bypass, in the normal key switch, almost always is in the harness from the key switch, but in the push-button ignition the cables goes direct to the bcm, and i cant find the manual for the rav4 to find the pulse, Hope you can helo.
Thks.
wisco_install
Member - Posts: 17
Posted: April 06, 2017 at 10:16 PM / IP Logged Link to Post Post Reply Quote wisco_install
This is everything i have on that car.
Battery     WHITE     (+)     DASH FUSE BOX WHITE 1 PIN PLUG     1
Ignition 1     WHITE     (+)     IGNITION SWITCH HARNESS     3     ON VEHICLES WITH PUSH BUTTON START THIS WIRE WILL BE YELLOW AND LOCATED AT THE DASH FUSE BOX, WHITE 56 PIN PLUG, PIN 14
Ignition 2     PINK     (+)     DASH FUSE BOX WHITE 48 PIN PLUG     43     ONLY ON VEHICLES WITH PUSH BUTTON START
Accessory 1     RED     (+)     IGNITION SWITCH HARNESS     7
Starter 1     WHITE     (+)     IGNITION SWITCH HARNESS     2     ON VEHICLES WITH PUSH BUTTON START THIS WITE WILL BE LOCATED AT THE DASH FUSE BOX, WHITE 56 PIN PLUG, PIN 26
Starter 2     LT. GREEN (SS1) GREEN (SS2)     (-)     START STOP SWITCH     5, 1     ONLY ON VEHICLES WITH PUSH BUTTON START
Key Sense     LT. BLUE     (-)     IGNITION SWITCH HARNESS
ONLY ON VEHICLES WITHOUT PUSH BUTTON START
Triggers
Wire Color     Polarity     Location     Plug/Pin #     Note     Picture
Front Left Door     WHITE     (-)     DASH FUSE BOX WHITE 40 PIN PLUG
Front Right Door     BLUE     (-)     ECU
Rear Left Door     WHITE     (-)     ECU
Rear Right Door     YELLOW     (-)     ECU
Dome Light Supervision     GRAY     (-)     DASH FUSE BOX WHITE 56 PIN PLUG     35
Hood Trigger     RED/WHIE     (-)     ABOVE DRIVERS KICKPANEL
ONLY ON VEHICLES WITH REMOTE START
Trunk/Hatch     LT. GREEN     (-)     DASH FUSE BOX WHITE 40 PIN PLUG     33
Lighting
All Parking Lights     GREEN     (+)     DASH FUSE BOX WHITE 40 PIN PLUG     18
Low Current Parking Light Trigger     WHITE     (-)     HEADLIGHT SWITCH     18
All Hazard Lights     GRAY     (-)     HARARD SWITCH     7
Low Beam Headlights     BLUE     (-)     HEADLIGHT SWITCH     19
Brake Lights     BLUE     (+)     DASH FUSE BOX WHITE 56 PIN PLUG     18
Reverse Lights     RED     (+)     DASH FUSE BOX WHITE 40 PIN PLUG
Integration
Power Lock     PINK     (-)     DRIVERS KICKPANEL
Power Unlock     BLACK     (-)     DRIVERS KICKPANEL
Trunk Release     RED     (-)     DRIVERS KICKPANEL
Factory Alarm Arm     BROWN     (-)     DRIVERS KICKPANEL
Factory Alarm Disarm     PINK     (-)     DRIVERS KICKPANEL
DOUBLE PULSE
Horn     LT. GREEN     (-)     DASH FUSE BOX WHITE 56 PIN PLUG     39
Parking Brake     BLACK     (-)     DASH FUSE BOX WHITE 56 PIN PLUG     34
Front Left Window Up     RED     (REV)     POWER WINDOW SWITCH IN DRIVERS DOOR     3     ONLY ON VEHICLES WITHOUT JAM PROTECTION
Front Left Window Down     GRAY     (REV)     POWER WINDOW SWITCH IN DRIVERS DOOR     4     ONLY ON VEHICLES WITHOUT JAM PROTECTION
Front Right Window Up     GREEN     (REV)     DRIVERS KICKPANEL
Front Right Window Down     BROWN     (REV)     DRIVERS KICKPANEL
Rear Left Window Up     RED     (REV)     DRIVERS KICKPANEL
Rear Left Window Down     BEIGE     (REV)     DRIVERS KICKPANEL
Rear Right Window Up     GREEN     (REV)     DRIVERS KICKPANEL
Rear Right Window Down     BROWN     (REV)     DRIVERS KICKPANEL
Rear Window Defrost     BLACK     (+)     DASH FUSE BOX WHITE 56 PIN PLUG     1     LATCHED
Driver Seat Memory 1     GREEN     (-)     DRIVERS KICKPANEL
Driver Seat Memory 2     PINK     (-)     DRIVERS KICKPANEL
Low Speed Wipers     BLACK     (+)     WIPER SWITCH     3
High Speed Wipers     RED     (+)     WIPER SWITCH     4
Sunroof Vent Open     GREEN     (-)     MAP LIGHT     5
Sunroof Vent Close     GRAY     (-)     MAP LIGHT     4     ONLY FUNCTIONS WITH IGNITION ON
Sunroof Full Open     RED     (-)     MAP LIGHT     2     ONLY FUNCTIONS WITH IGNITION ON
Sunroof Full Close     BLACK     (-)     MAP LIGHT     3     ONLY FUNCTIONS WITH IGNITION ON
OE Anti-Theft Wiring
Anti-Theft RX     RED     (DATA)     ABOVE DRIVER KCIKPANEL
Anti-Theft TX     BLUE     (DATA)     ABOVE DRIVER KICKPANEL
CANbus     BLACK     (DATA)     OBDII PORT     6
Engine Wiring
Tach     GRAY     (AC)     OBDII PORT     9
Safety Systems
Yes/No
Drivers Side Airbag Equipped     YES
Passenger Side Airbag Equipped     YES
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
