Brake lights reversed
rebubula
Posted: July 31, 2017 at 2:29 PM / IP Logged Link to Post Post Reply Quote rebubula
Hello, as a temporary fix for non-working brake lights for the summer, I wanted to put mounted trailer lights to use as brake lights. All other lights work, turn signals, tail lights, reverse lights. My problem is when I connect the lights, it is reversed. When brake pedal is not depressed, the brake lights are on. When I depress the brake pedal, the brake lights go out. Is there a way to reverse it using a 5 pin relay switch?
rebubula
Posted: July 31, 2017 at 2:31 PM / IP Logged Link to Post Post Reply Quote rebubula
1991 VW vanagon. This is the original problem. click the link. https://www.thesamba.com/vw/forum/viewtopic.php?t=683390&highlight=
Matt
