Create 12+ When Ground Is Lost
alan.c
Posted: August 15, 2017 at 5:09 PM / IP Logged Link to Post Post Reply Quote alan.c
Hi guy's.
This is my first post, I'm somewhat of a newbie when it comes to car electrics..
OK so basically I'm trying to wire up a radiator cooling fan. The fan thermo switch is a single wire and is grounded when the engine is cold, when the engine gets to up to temperature the ground is lost..
I need to wire up a relay that will allow the cooling fan to come on when the engine is up to temperature.
Is there a simple way to wire this up and with using just one relay?
Thanks is advance
Alan.
the12volt
Administrator - Posts: 3,957
Posted: August 15, 2017 at 5:15 PM / IP Logged Link to Post Post Reply Quote the12volt
Using an SPDT relay, wire as follows:
30 and 85 to ignition 12V+
86 to ground from thermo switch
87a 12V output to cooling fan
87 not used
Create 12+ When Ground Is Lost - Last Post -- posted image. the12volt • Support the12volt.com
alan.c
Posted: August 15, 2017 at 5:24 PM / IP Logged Link to Post Post Reply Quote alan.c
Perfect I'll try this tomorrow and let u know how I get on.
Alan.
Platinum - Posts: 13,723
Posted: August 15, 2017 at 5:53 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Are you powering the fan with the relay? Or is the relay providing a low current signal to some type of controller?
alan.c
Posted: August 16, 2017 at 1:09 AM / IP Logged Link to Post Post Reply Quote alan.c
Powering the fan from the relay
Posted: August 16, 2017 at 10:53 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Cooling fans tend to pull high amounts of current at startup. You may want to use a second relay to power it directly off the battery. Do not connect the single relay to an ignition wire of your vehicle.
alan.c
Posted: August 16, 2017 at 12:14 PM / IP Logged Link to Post Post Reply Quote alan.c
At the moment I have it wired directly to the battery via a 15amp fuse and single relay as mentioned above.
I'm not to sure how I'd go about wiring up a second relay
Posted: August 16, 2017 at 12:27 PM / IP Logged Link to Post Post Reply Quote i am an idiot
As long as you have it directly to the battery you are fine. I just did not want you pulling tons of current through an ignition wire.
Wednesday, December 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
