2nd ign, acc location 9 gen civic si?
daves06xa
Member - Posts: 9
Posted: October 09, 2017 at 12:42 PM / IP Logged Link to Post Post Reply Quote daves06xa
installing evo all with viper 5906v.. I need to tap 2 accessory. They say it's at the smart module which is impossible to access. Is there an easier location please help...this is a 9 gen si coupe. 2015
Platinum - Posts: 13,726
Posted: October 09, 2017 at 6:13 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Smart Key? If so, Directechs has green dash sub relay box above dash fuse box, white 7 pin plug, pin 2. It is in the same harness that has Ignition and Accessory.
daves06xa
Member - Posts: 9
Posted: October 10, 2017 at 2:23 AM / IP Logged Link to Post Post Reply Quote daves06xa
Thx 4 help. Turns out you only need that wire when you want to have oem key fob work while car is running when using evo all. It's not worth digging down to tap the wire.
daves06xa
Member - Posts: 9
Posted: October 10, 2017 at 8:57 AM / IP Logged Link to Post Post Reply Quote daves06xa
Installing evo all and viper 5906v. I need to find ignition2 location. Fortin shows above junction location at the module but it's impossible to get to because connector is right being bracket and the clip release is on top side which even more difficult. I will need this circuit to complete viper install. Anyone have an easier location to access. Please help..
sparkie
Platinum - Posts: 2,061
Posted: October 10, 2017 at 4:51 PM / IP Logged Link to Post Post Reply Quote sparkie
Remove the 3 10mm bolts that hold the bracket. Unplug the 3 connectors and pull the module out. You can then tap into the wires. It helps to remove the plastic steering column trim and it will make it easier to get your hands in there. Use a good light to help see. It's not easy but it is possible.
sparky
daves06xa
Member - Posts: 9
Posted: October 10, 2017 at 5:11 PM / IP Logged Link to Post Post Reply Quote daves06xa
Yea I saw the bracket and looked at bolts but looked like they were inaccessible.whoever chose that point played a sick joke. There must be an easier place. Even in a wire loom. Have you actually removed one? All my plastic is off I'll give it a go shortly. Thx 4 your help...
daves06xa
Member - Posts: 9
Posted: October 12, 2017 at 7:37 AM / IP Logged Link to Post Post Reply Quote daves06xa
Do you absolutely need to hook up ignition2 to viper to   have have the remote start work? 2hat does the viper do that signal
Please help this is the final connection
sparkie
Posted: October 12, 2017 at 5:08 PM / IP Logged Link to Post Post Reply Quote sparkie
Yes. I've done many Civics. If the wires are shown in the install guide, you need to connect them.
sparky
daves06xa
Member - Posts: 9
Posted: October 12, 2017 at 7:51 PM / IP Logged Link to Post Post Reply Quote daves06xa
Thanks so much sparkie.. Not doubting your experience of trying to troll you but I'm at my wits end.. I've had my car tore apart for a week and been working with crutchfied and no luck so far ..it's annoying. I need to talk to someone that has actually successful done this and you sound like the man...
daves06xa
Member - Posts: 9
Posted: October 13, 2017 at 6:20 PM / IP Logged Link to Post Post Reply Quote daves06xa
Good news. I found all wires and my remote is working..... Thanks to the forum and special thanks to sparkie...
