2015 Jeep Wrangler TIPM LED problem
jsigna
Copper - Posts: 157
Posted: October 17, 2017 at 6:21 PM / IP Logged Link to Post Post Reply Quote jsigna
Hey all,
Experiencing a really annoying issue.
Installed LED Headlight bulbs H13 into a 2015 Jeep Wrangler.
Noticed a slight flicker and also get intermittent periods where we get TIPM warnings which say, "no buS" and the low beams refuse to shut off. Not to mention the windshield wipers go back and forth. Decided to try Anti-Flicker LED Resistors (the gold ones) plug and play. No dice. The flicker remained and intermittent TIPM issues.
So I wired relays for both low beams individually utilizing the led resistors on the source feed side of the relay. Flicker is gone (yay!), still getting intermittent TIPM bug outs.
I was thinking of switching the load resistors to 4700uf capacitors but I wanted to reach out to you guys to see what any of you might think.
I am actually losing my mind on this, so any help would be awesome.
Thanks!
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
