AS-1780 installation on 98 crv
hardrew_rolly
Member - Posts: 32
Posted: October 31, 2017 at 5:36 AM / IP Logged Link to Post Post Reply Quote hardrew_rolly
Hi guys, I need help installing autostart 1780 on my 1998 honda crv with automatic transmission.
Here is what happening:
I already hooked up all the wires. Remote starts works but the starter solenoid won't disengage. Another thing is when I use the key to start the car, I am not yet on the crank position only accessories the engine will start and same thing happen the starter solenoid won't disengage.
Connections I made:
-Yellow(ignition) connected to black Yellow on the car
-red(12v battery) connected to white on the car
-orange(acc) connected to yellow on the car
-I used starter kill relay. Cut the black white starter wire connect to 87a of the relay together with the purple(starter wire of the remote) to the solenoid side of the starter, 30 on the key side of starter, 85 to the igniton(+) and 86 to the starter kill output on the remote starter.
I am getting frustrated. Please help guys.
silvercivicsir
Copper - Posts: 416
Posted: November 01, 2017 at 5:02 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
wiring sounds correct.. you might have a bad brain.. (try probing the purple starter wire, when you turn the key, it's getting power from somewhere).
