Remote Start Issue, 2002 GMC Sierra
drdanknuggs
Posted: November 14, 2017 at 12:26 PM / IP Logged Link to Post Post Reply Quote drdanknuggs
Recently installed RS in my 2002 gmc Sierra, everything works great except one issue I just found. I just replaced all the bulbs in my car with LEDs everything works great except window/lock switch lights, interestingly enough they Do work but only when car is running under remote start once i put the key in turn & shift into gear lights go off, so once the car takes over from RS its lights out. I was thinking something with dome light sup but wasn't sure. Any thought would be appreciated if someone could at least point me in the right direction. Thanks for your time look forward to hearing from someone!
dcman41
Copper - Posts: 211
Posted: November 15, 2017 at 2:18 PM / IP Logged Link to Post Post Reply Quote dcman41
check interior light fuses / parking light fuse. The remote start is powering the parking light circuit which is why its running while the remote start is active. I can almost bet your parking lights wont work either when the remote start is not engaged
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
