2014 Focus door pins
trailer11
Posted: November 30, 2017 at 11:11 AM / IP Logged Link to Post Post Reply Quote trailer11
Installing remote start for manual transmission. It seems like all the door pins are negative with doors shut. Im using wiring info from this site but it say negative NC    What does this mean?
Posted: November 30, 2017 at 11:50 AM / IP Logged Link to Post Post Reply Quote howie ll
Use the dome light supervision wire.
White/brown grey plug at BCM.
Platinum - Posts: 13,725
Posted: November 30, 2017 at 3:49 PM / IP Logged Link to Post Post Reply Quote i am an idiot
I am pretty sure that if you do domelight wire on that vehicle, exactly 10 minutes in it will false. Every time. You need this or equivalent http://codealarmremotes.com/inc/sdetail/voxx-nctm-normally-closed-trigger-module/1909
Posted: November 30, 2017 at 6:37 PM / IP Logged Link to Post Post Reply Quote howie ll
That or use a data module such as a DB-ALL; does it for you, includes the immobiliser by-pass and saves a good hour of labour and the answer BTW to the false alarming is a 1N4004 to the + feed to each dome light.
trailer11
Posted: December 01, 2017 at 8:31 PM / IP Logged Link to Post Post Reply Quote trailer11
ok. Dome supervision dont work. cuz dome light comes on when car shuts down
Posted: December 01, 2017 at 11:00 PM / IP Logged Link to Post Post Reply Quote howie ll
Which shuts off when you lock the vehicle.
