Ultrastar TR-1 or similar Tranponder Bypass
takeo
Posted: December 17, 2017 at 5:54 PM / IP Logged Link to Post Post Reply Quote takeo
Good day every one.
Recently after a hours of installation of my first car alarm learned a lot about them. Alarm I have is a genuine ebay push button with a fob. It is cheap and suits none of my purposes, but one. I want to keep push start wiering and button with a OEM alarm I already have. I have 2010 Honda Accord Coupe 4Cylinder.
Here is how I see it.
1. I have a OEM keyfob with which I open doors windows trunk and so on.
2. I have button installed in the car and it can start the car only when I apply brake.
3. When I sit in my seat car(TR-1 Bypass senses my key fob and car starts without shutting of.
Here what I have already done.
1. I have button already wired up to the car. When I apply brake it will start it just with one click. (Key is not in the ignition) it will shut off the car because keyhole doesn't recognize the transponder.
2. I have the Ultrastar TR-1 unit which is wired to the car and if I put my key inside of the gray antena car will sense and start with push button without shutting off.
Ultrastar TR-1 or similar Tranponder Bypass - Last Post -- posted image.
(Key goes inside of the box in the gray receiver.)
Antena from the TR-1 goes to ignition key hole. (Wires on the left side.)
What do I need? I want to keep a key in my pocket and be able to start the car with push start button.
How can I do it? Well here is the plan and my question.
I want to spend how use this box as my new transponder key receiver redifecting it to the cars keyhole using antena from picture above. I hide the box under my seat and when it senses my key it activates and tells car that key fob is here with transponder. I use push button to start.
Problem I have. Ultrastar TR-1 has a really small distance of transponder sense of have to be very close. I want to some how amplifie that signal. Not far at all, enough so when I sit down it reaches from my pocket to the under the seat. About 1 ft max.
How can I amplifie that rfid signal from TR-1?????? I was thinking about adding a lot of copper wiering to the grey part this creating a bigger single. I can be wrong. Noob after all.
If it possible which i am sure is.. well then I have stock alarm and a push start button which works only when my OEM key is with me.
Boris Fua
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
