RS need more ignition outputs?
keenxxx
Member - Posts: 27
Posted: December 19, 2017 at 4:05 PM / IP Logged Link to Post Post Reply Quote keenxxx
I am installing a Compustar CM 7000 in a 2003 S10 blazer. Minimal connections requires 2 inputs to run and operate the HVAC - Compustar has only to outputs white & blue. There is a green wire they call an input/output for programming so I am not sure what this wire does during a remote start. My last install had enough outputs to power The Blazer's white wire which controls the instrument cluster etc. Any idea's how to add outputs in general or on the Compustar? Thanks.
geepherder
Platinum - Posts: 3,668
Posted: December 19, 2017 at 5:55 PM / IP Logged Link to Post Post Reply Quote geepherder
If you only need one more output, connector 1 has a blue wire that's set to ignition2. If you need two, use the blue wire to trigger two relays.
keenxxx
Member - Posts: 27
Posted: December 19, 2017 at 6:15 PM / IP Logged Link to Post Post Reply Quote keenxxx
Ah yes. I kept visualizing the 2nd ignition still connected to the circuit then branching to a single relay only to become energized by the key switch as well. Divorce both wires and run 2 relays RS need more ignition outputs? - Last Post -- posted image.
Seems like some less expensive RS employ more ignition outputs.
