2016 Ram - Horn Wire
devonow
Posted: December 31, 2017 at 2:54 AM / IP Logged Link to Post Post Reply Quote devonow
Hooking up the Fortin EVO all remote start with alarm feature. The instructions say to find the negative horn wire but dont know where to look. Can anyone post a pic on where to find it? What color is the wire?
Chris
geepherder
Platinum - Posts: 3,668
Posted: December 31, 2017 at 7:25 AM / IP Logged Link to Post Post Reply Quote geepherder
from Bulldogsecurity.com:
http://diagrams.marktoonen.nl/printlist.aspx?MakeID=116&ModelID=20506
devonow
Posted: December 31, 2017 at 10:38 AM / IP Logged Link to Post Post Reply Quote devonow
Thanks but isnt that the positive wire (+)? Im looking for the negative wire.
Chris
geepherder
Posted: December 31, 2017 at 1:27 PM / IP Logged Link to Post Post Reply Quote geepherder
Right, you are. Here's a diagram of the factory wiring:
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=1154411
You'll see there isn't a switched negative wire for the horn. You're best bet is to use a relay to switch polarity:
https://www.the12volt.com/relays/relaydiagram9.html
devonow
Posted: December 31, 2017 at 3:19 PM / IP Logged Link to Post Post Reply Quote devonow
Thanks jeepherder! Thats exactly what I needed! Would these relays work for this polarity conversion?
Can I also use this relay for the anti grind relay? I guess what Im asking is if it is the correct type for both applications (40a 14VDC). Of course I know that I will need 2.
2016 Ram - Horn Wire - Last Post -- posted image.
Chris
geepherder
Posted: December 31, 2017 at 3:33 PM / IP Logged Link to Post Post Reply Quote geepherder
Yes, those will work just fine.
devonow
Posted: December 31, 2017 at 3:58 PM / IP Logged Link to Post Post Reply Quote devonow
One more question! Below is a pic of my ignition plug. Would it be correct by wiring the anti grind relay- 12V constant (red) to the 86 pole and the starter wire (violet) to the 30 pole and then again after cutting the (violet) starter wire to the 87a pole. 85 goes to (-) controller.
Chris
geepherder
Posted: December 31, 2017 at 4:39 PM / IP Logged Link to Post Post Reply Quote geepherder
https://www.the12volt.com/installbay/forum_posts.asp?tid=90800&tpn=1
The above listed post has an explanation for wiring the anti grind relay.
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
