check wiring 2003 suburban
motorsportsx
Member - Posts: 6
Posted: January 26, 2018 at 8:59 PM / IP Logged Link to Post Post Reply Quote motorsportsx
Hey guys. I have written out the 6 pin and 10 pin connectors and hoping you can take a look. And let me know if what i have is right and if the question marks i have written can get sorted out.
Alarm is a viper 5906 and bypass is an ALCA flashed for gm d2d.
I do have one question not on the picture... The alca ask for an ign+ from the viper... I'm not sure where to get this from. Hellppp lol.
Thanks for the help everyone! (Ill get the 24 pin sorted next)
check wiring 2003 suburban - Last Post -- posted image.
motorsportsx
Member - Posts: 6
Posted: January 26, 2018 at 10:57 PM / IP Logged Link to Post Post Reply Quote motorsportsx
I think i got most everything answered from anther source. Just to verify. I can user just one starter wire (7) if i choose right?
Platinum - Posts: 7,828
Posted: January 27, 2018 at 7:06 AM / IP Logged Link to Post Post Reply Quote kreg357
Yes, if you don't want / need Starter Kill and Anti-Grind, you can leave the vehicles Starter wire uncut and just
connect the Vipers Violet Starter wire.
As for the ADS AL-CA w/DBI DL GM1 firmware, the ADS AL-CA Pink Ignition wire would connect to the Vipers thick Pink
IGN1 wire. which in-turn would go the vehicles Pink IGN1 wire.
Looking at the Type 3 wiring diagram in the DBI DL GM1 install guide #39306, it would appear that they failed to
make the line connection from the ADS AL-CA DATA ORANGE - DATA (J1850) wire to the indicated OBD2 wire. Remember
that the diagram is somewhat generic and does not show everything needed for the many different type of R/S units
supported. You would still need the Viper connections like Neutral Safety, Hood Pin and possibly others.
