Aftermarket Keyless Entry with Dash Switch?
aolis110
Posted: June 04, 2018 at 4:32 PM / IP Logged
Hi, everyone, I'm hoping you guys can help me out here. I installed power door locks in my'03 F100. They are the factory two wire actuators controlled by a five wire rocker switch mounted on the dash. I'm not using relays. They worked great until I attempted to also connect an Ebay after market keyless entry. When I attempted to use the keyless entry, I burned it out and blew out the fuse I had going to the rocker switch.I know I'm crossing wires somewhere, or maybe I have to use relays. This time I have an Avital 2101L keyless entry I want to install, but I don't want to burn it out. Any help would be greatly appreciated.
Tommy110
the12volt
Administrator - Posts: 3,959
Posted: June 04, 2018 at 4:35 PM / IP Logged
Wire two SPDT relays like this: https://www.the12volt.com/relays/relaydiagram3.html
Aftermarket Keyless Entry with Dash Switch? - Last Post -- posted image. the12volt • Support the12volt.com
the12volt
Posted: June 04, 2018 at 4:49 PM / IP Logged
aolis110
Posted: June 04, 2018 at 6:17 PM / IP Logged
Thank you for the quick response!
Tommy110
the12volt
Posted: June 04, 2018 at 6:42 PM / IP Logged
You're welcome!
