2016 Nissan Sentra Rear Speaker Wires?
downhillrcr
Posted: September 08, 2018 at 11:54 AM / IP Logged Link to Post Post Reply Quote downhillrcr
2016 Nissan sentra sr rear speaker colors are orange white gray green which is positive? cant find these colors anywhere think its orange positive gray positive just want to make sure thx six speaker system 2 tweeters in window panel 2 door speakers I assume midrange and the rear all cheap, rears are 50 watt junk 9 by six any help would be great thx it does have a smart key
mark platten
Platinum - Posts: 13,725
Posted: September 08, 2018 at 7:13 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Do the rear speakers work? If so you can use a 9 volt battery to figure it out. Remove the plug so you do not feed voltage to your radio. Attach wires to the speaker terminals. Touch the other end of those wires to the 2 terminals of the battery. Notice the direction of the cone. If the cone travels up (away from the magnet) you have the positive terminal of the battery connected to the positive terminal of the speaker.
downhillrcr
Posted: September 09, 2018 at 9:46 AM / IP Logged Link to Post Post Reply Quote downhillrcr
which wires are positive or negative not the speakers :) sorry
mark platten
Posted: September 09, 2018 at 12:53 PM / IP Logged Link to Post Post Reply Quote i am an idiot
When you find the positive terminal of the speaker, plug the harness back into the speaker and notice which wire is then connected to the positive terminal. That will be your positive wire.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
