2008 Lexus IS250 Remote Start
myrdhyn
Posted: October 25, 2018 at 3:48 PM / IP Logged Link to Post Post Reply Quote myrdhyn
I am planning out a remote start install using a CM7200S. It has connections for either a high current or low current ignition harness. Anyone done one of these installs before and know which I should use? Also, if done before, tips?
I found this thread: https://www.the12volt.com/installbay/forum_posts.asp?tid=103587 for the wiring info I need, but it does not have any info about if it is high or low current.
Edit: Looks I just answered my own question when reviewing the manual for the Blade TB I will be using as well. The wiring diagram shows us getting power from the brake pedal and using a 12v relay and a 1N4001 diode.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
