Do I Need Relays for Avital 4105 Remote Start?
msufan06
Posted: November 06, 2018 at 5:52 PM / IP Logged Link to Post Post Reply Quote msufan06
Do I need to use Relays for the Avital 4105 Remote start, working on installing it in a 2001 Ford Explorer Sport, also do I need the 2nd ignition wire or if anyone can give me some pointers on what wires I need to use and what I dont need!!! Any and all help is appreciated.
chev104275
Gold - Posts: 1,436
Posted: November 06, 2018 at 7:09 PM / IP Logged Link to Post Post Reply Quote chev104275
I always power everything just like the key does. That truck should have 2 ingition wires and 2 acc wires. The 4105 has 1 ingition out , 1 acc out and 1 programmable for ing or acc. It also has negative outputs to control relays. So you will need at least one relay for the added ing or acc depending on how to decide to wire the system
msufan06
Posted: November 06, 2018 at 7:31 PM / IP Logged Link to Post Post Reply Quote msufan06
Do I need to wire the 2nd ignition or will it work with just the 1 ignition hooked up? Thank you for your help!!
chev104275
Gold - Posts: 1,436
Posted: November 07, 2018 at 4:57 AM / IP Logged Link to Post Post Reply Quote chev104275
I would do both ingitions and both acc wires
msufan06
Posted: November 07, 2018 at 2:05 PM / IP Logged Link to Post Post Reply Quote msufan06
Awesome thanks for your help!!
silvercivicsir
Copper - Posts: 416
Posted: November 07, 2018 at 4:39 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
both accessories are not needed, just need to find the one that turns on the "heater fan", the other one turns on the radio.
msufan06
Posted: November 07, 2018 at 5:18 PM / IP Logged Link to Post Post Reply Quote msufan06
So just make sure i get both ignition wires hooked and the one acc?
silvercivicsir
Copper - Posts: 416
Posted: November 07, 2018 at 10:33 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
both ignitions and only one accessory are needed for it to start / turn on the blower motor.
Sunday, July 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
