Valet 561/562 Lights Flash, No Lock or Unlock or Start
keebz489
Member - Posts: 9
Posted: December 18, 2018 at 1:21 PM / IP Logged Link to Post Post Reply Quote keebz489
first post here , used the site for tips dozens of times over the years on audio , but alarms I am clueless on.    I have a viper 5706v I pulled from my 2012 pilot when I got rid of it. I bought a 05 trailblazer ext to use for work , i went to the local shop i used , he said $200 just to install the viper , i don't have the cash to waste right now and im ok with the valet brand remote start but now its December and it stopped working.   typical luck      the lights flash when i hit lock / unlock , but nothing happens , same with remote start.   i don't know where to start looking but i hate a 20* car at 530 am !        sitting in the car i hear no relay clicking when i try the lock , possible fuse somewhere ?
any help is extremely helpful
keebz489
Member - Posts: 9
Posted: December 18, 2018 at 1:53 PM / IP Logged Link to Post Post Reply Quote keebz489
also if I start the car and hit the remote start button while engine is on it will work normal so I can take my key out and run into a store , so i am guessing the tach is wired / programmed corrrectly and what ever bypass i have , otherwise it wouldnt run while in teh store???
geepherder
Platinum - Posts: 3,668
Posted: December 19, 2018 at 7:30 AM / IP Logged Link to Post Post Reply Quote geepherder
Have you contacted the dealer about fixing it?
keebz489
Member - Posts: 9
Posted: December 19, 2018 at 3:54 PM / IP Logged Link to Post Post Reply Quote keebz489
I don't know where it was installed , its an 05 that I bought used a year ago   , also I made a typo , I DO hear the relay click while sitting in the car
silvercivicsir
Copper - Posts: 416
Posted: December 20, 2018 at 3:48 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
look under the dash, and see if the toggle switch is "off" or broken.
keebz489
Member - Posts: 9
Posted: December 24, 2018 at 11:37 AM / IP Logged Link to Post Post Reply Quote keebz489
there is no toggle switch that I can see , it was working one day then stopped the next.   I will look more later today , in "off" I assume you mean it would be in a valet mode ?   if so wouldn't the door still lock if I press the remote ?
Tuesday, September 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
