2019 Chevrolet Equinox Remote Start Wiring
grad01
Member - Posts: 10
Posted: February 02, 2019 at 7:09 PM / IP Logged Link to Post Post Reply Quote grad01
I am trying to install a Firstech 7200 remote start module and am looking for the wire diagram/color code on the Equinox side to connect to. I am not installing an alarm - only remote start.
Thank you for any help
Platinum - Posts: 13,725
Posted: February 03, 2019 at 6:09 PM / IP Logged Link to Post Post Reply Quote i am an idiot
12 Volts      Red/Brown (20A)      +      BCM in center console front passenger side, blue 27 pin plug, pin 4
Ground      (chassis ground)
Starter      Yellow (for starter kill only)      +      Starter Motor or Underhood Fuse Box, gray 60 pin plug (X3), pin 34
Ignition      Violet/Black      +      BCM in center console front passenger side, green 25 pin plug, pin 6
Accessory      Violet/Yellow      +      BCM in center console front passenger side, green 25 pin plug, pin 5
PTS 1      Blue/Green      - 1300 Ohms      BCM in center console front passenger side, blue 27 pin plug, pin 17
CAN Bus High      Blue      Data      BCM in center console front passenger side, blue 27 pin plug, pin 24
CAN Bus Low      White      Data      BCM in center console front passenger side, blue 27 pin plug, pin 23
CAN Bus High 2      Blue      Data      OBD-Data Link Connector, black 16 pin plug, pin 6
CAN Bus Low 2      White      Data      OBD-Data Link Connector, black 16 pin plug, pin 14
CAN Bus SW      Green      Data      BCM in center console front passenger side, blue 27 pin plug, pin 22
CAN Bus SW 2      Green      Data      OBD-Data Link Connector, black 16 pin plug, pin 1
OBD 12 Volts      Red/Violet (10A)      +      OBD-Data Link Connector, black 16 pin plug, pin 16
OBD Ground      Black      -      OBD-Data Link Connector, black 16 pin plug, pin 4
IMMO Data      Green/Violet      Data      BCM in center console front passenger side, green 25 pin plug, pin 2
grad01
Member - Posts: 10
Posted: February 09, 2019 at 9:35 PM / IP Logged Link to Post Post Reply Quote grad01
Thank you this is great - would you have the wires & location for the doors lock/unlock?
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
