1992 Lincoln Town Car, No Click, No Start
codyooo1
Posted: March 06, 2019 at 5:51 AM / IP Logged Link to Post Post Reply Quote codyooo1
Starter works on test bench.
Will not work in car
Platinum - Posts: 13,725
Posted: March 06, 2019 at 6:22 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Do you have a volt meter? Is the starter solenoid mounted on the inner fender?
codyooo1
Posted: March 06, 2019 at 11:58 AM / IP Logged Link to Post Post Reply Quote codyooo1
Yes,I have volt meter
Solenoid is on starter
codyooo1
Posted: March 06, 2019 at 12:06 PM / IP Logged Link to Post Post Reply Quote codyooo1
Kinda/ think anti theft?
This car should be running.
Put in a transmission.
Drove it for 3 weeks.
Last 2 sarts sound d like it was going dead ,then, _0_.
Take it out of car, jumper cables,starter&selenoid work.also,had juju t checked at oreilley
geepherder
Platinum - Posts: 3,668
Posted: March 06, 2019 at 2:19 PM / IP Logged Link to Post Post Reply Quote geepherder
See if the white/pink wire at the ignition harness has power in the start position.
Posted: March 07, 2019 at 8:43 AM / IP Logged Link to Post Post Reply Quote i am an idiot
You will have to get to the starter connections. With somebody holding the key in the start position check voltage on the small wire. And with the key still in the start position check voltage on the large wire coming from the battery. 1 of them will not have 12 volts on it. Let us know which one does not.
codyooo1
Posted: March 10, 2019 at 1:43 AM / IP Logged Link to Post Post Reply Quote codyooo1
Found broken trunk motor connector
Anti theft . Killed starter
codyooo1
Posted: March 10, 2019 at 1:45 AM / IP Logged Link to Post Post Reply Quote codyooo1
All wires have 13.65 volts in start position
Posted: March 10, 2019 at 6:03 PM / IP Logged Link to Post Post Reply Quote i am an idiot
How many is all?
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
