2000 GMC Sierra Power Lock
scottmorris
Member - Posts: 6
Posted: May 02, 2019 at 1:40 PM / IP Logged Link to Post Post Reply Quote scottmorris
Hello, I have a 2000 GMC Sierra and I recently installed a viper 5105v rs/alarm kit. The problem I am having however is with the door locks. I had to install two aftermarket lock actuators, as my doors are manual. I bought the 451m relay but had no luck getting it to work with my application. I later bought two 5-pin relays and wired them up and got the locks to function, but they lock when commanded unlock and vice-versa. I cannot for the life of me figure out how to fix this issue. I’ve tried reversing polarity on the driver side master lock, but the locks would only have one function if I did so. I have triple checked my wiring on the relays, but have came up short each time. Help me please!!!
geepherder
Platinum - Posts: 3,668
Posted: May 02, 2019 at 3:42 PM / IP Logged Link to Post Post Reply Quote geepherder
Swap the lock and unlock wires on the Viper.
scottmorris
Member - Posts: 6
Posted: May 02, 2019 at 4:28 PM / IP Logged Link to Post Post Reply Quote scottmorris
how exactly would I go about doing this?
Platinum - Posts: 13,720
Posted: May 02, 2019 at 9:28 PM / IP Logged Link to Post Post Reply Quote i am an idiot
What color are the lock and unlock wires of the alarm system? Remove the lock wire and connect it to the other relay. Put the unlock wire on the relay you took the other wire from.
geepherder
Posted: May 02, 2019 at 10:02 PM / IP Logged Link to Post Post Reply Quote geepherder
You could cut the lock and unlock wires and connect blue to green and green to blue.
Or you could change them at the relays as suggested above. Either way it accomplishes the same thing.
scottmorris
Member - Posts: 6
Posted: May 02, 2019 at 10:44 PM / IP Logged Link to Post Post Reply Quote scottmorris
Thanks for the replies guys. I will try this after work tomorrow and let you know the results.
scottmorris
Member - Posts: 6
Posted: June 25, 2019 at 2:46 PM / IP Logged Link to Post Post Reply Quote scottmorris
Thanks everyone, they function as they should now.
2000 RCSB Sierra
4.10 gears with Yukon Duragrip
Built 4L60E
Custom HP Tune by Me
Viper 5105v
Power lock and window conversion
Rockford Fosgate 300.1
2 JL Audio 12s
Custom Ported Enclosure by M
Saturday, September 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
