2005 Ford Focus Ignition Transponder Bypass
rickyfix
Posted: June 21, 2019 at 7:40 PM / IP Logged Link to Post Post Reply Quote rickyfix
I have a focus with no keys I have drilled out the ignition lock cylinder and want to bypass the Pats system. Will the 555s bypass do what I need it to without a key?
RickyFix
Platinum - Posts: 13,725
Posted: June 22, 2019 at 8:24 PM / IP Logged Link to Post Post Reply Quote i am an idiot
I do not know of any bypass that will work without a functioning key.
rickyfix
Posted: June 26, 2019 at 9:49 AM / IP Logged Link to Post Post Reply Quote rickyfix
By, "functioning key", I assume you mean one that's programmed to the car already? If so, what are my options? The mechanical function of the key isn't an issue, I ordered another lock cylinder with keys and dongle for programming new keys - but old is needed, I'm assuming the dongle picks up the code from the original key, saves it, then programs new keys & cpu to match. If someone loses their keys, there's got to be a way....
RickyFix
geepherder
Platinum - Posts: 3,668
Posted: June 26, 2019 at 6:55 PM / IP Logged Link to Post Post Reply Quote geepherder
Without a functioning key, your most likely fixes are either the dealer, or possibly a locksmith.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
