2013 Dodge Challenger R/T Wiring Diagram
cabron19
Member - Posts: 15
Posted: June 22, 2019 at 2:31 AM / IP Logged Link to Post Post Reply Quote cabron19
The subject says it all. Any help would be greatly appreciated.
Mostly needing info related to security system wiring. Thanks in advance.
cabron19
Member - Posts: 15
Posted: June 22, 2019 at 2:33 AM / IP Logged Link to Post Post Reply Quote cabron19
The car is a "push button start".
wirewise
Moderator - Posts: 489
Posted: June 22, 2019 at 5:32 AM / IP Logged Link to Post Post Reply Quote wirewise
CHALLENGER      2010-2014
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      CHRYSLER'S MULTIPLEX IGNITION/ANTI-THEFT SYSTEM, SEE NOTE #1
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      RED (+)      @ BATTERY or TIPM, Note #2
STARTER      CONNECTION MADE AT INTERFACE BYPASS MODULE
STARTER 2      N/A
IGNITION 1      PINK/WHITE (+)      @ IGNITION SWITCH (BLACK,12 PIN PLUG) PIN 3
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY/HEATER BLOWER 1      N/A
ACCESSORY/HEATER BLOWER 2      N/A
KEYSENSE      N/A
PARKING LIGHTS ( - )      N/A
PARKING LIGHTS ( + )      WHITE/PURPLE (+)      in PASSENGER KICK PANEL, Harness to Rear of Vehicle.
POWER LOCK      PURPLE/DK.GREEN (-) ONE WIRE SYSTEM      (-) THRU 330 OHM DRIVERS KICK (in door harness)or GRAY 26 PIN PLUG, PIN 5 at instrument cluster
POWER UNLOCK      Use LOCK wire, (-) thru a 100 Ohm Resistor      (-) THRU 100 OHM SAME WIRE AS LOCK
LOCK MOTOR WIRE      LT. GREEN (5 WIRE)      DRIVERS KICK PANEL(door harness) or GRAY 26 PIN PLUG, PIN 12 at INSTRUMENT CLUSTER
DOOR TRIGGER      PURPLE (-)      in DRIVERS KICK PANEL or INSTRUMENT CLUSTER, WHITE 26 PIN PLUG PIN 3
DOMELIGHT SUPERVISION      YELLOW/WHITE (+)      @ PASSENGER A PILLAR or INSTRUMENT CLUSTER, WHITE 26 PIN PLUG, PIN 8
TRUNK RELEASE      PURPLE/TAN (-)      @ RELEASE SWITCH or INSTRUMENT CLUSTER, (GRAY 26 PIN PLUG) PIN 22
SLIDING POWER DOOR      N/A
HORN      N/A
TACH      NOT BROWN/WHITE(V6) OR BROWN (V8)      (AC) @ Any FUEL INJECTOR
WAIT TO START LIGHT
BRAKE      DK. GREEN/WHITE (+)      @ BRAKE SWITCH or BLACK 12 PIN PLUG, PIN 12, @Wireless Ign. Node on Ign. Switch
FACTORY ALARM DISARM      SENTRY KEY AND IGNITION
ANTI-THEFT      CHRYSLER'S MULITPLEX IGNITION/ANTI-THEFT SYSTEM
NOTES
NOTE #1 REMOTE START REQUIRES INTERFACE/ ANTI -THEFT MODULE PART # DBALL2 .
NOTE #2 TIPM IS LOCATED ON PASSENGER SIDE FENDER UNDER HOOD
~wirewise~ Verify all wiring with your meter before making any connections!
cabron19
Member - Posts: 15
Posted: June 23, 2019 at 1:42 AM / IP Logged Link to Post Post Reply Quote cabron19
Thank you wirewise!!!
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
