2018 Ford Ecosport Remote Start
bluefrgcaraudio
Posted: July 01, 2019 at 9:24 PM / IP Logged Link to Post Post Reply Quote bluefrgcaraudio
I need help installing an aftermarket remote start in my wife's 2018 Ford Ecosport. It's a plug and play but I need to ground the bcm because there's no hood pin. I have no idea how I am supposed to do this, I believe I know where the bcm is but I don't know where on the bcm to ground and where to ground it. Hope that makes sense.
catback
Silver - Posts: 703
Posted: July 01, 2019 at 10:05 PM / IP Logged Link to Post Post Reply Quote catback
It would help to know what you are installing (make and model).
bluefrgcaraudio
Posted: July 02, 2019 at 1:59 PM / IP Logged Link to Post Post Reply Quote bluefrgcaraudio
Directed DB3
catback
Silver - Posts: 703
Posted: July 02, 2019 at 3:33 PM / IP Logged Link to Post Post Reply Quote catback
Your Ecosport does not give any hood open warnings if you open the hood with the vehicle running?
If not then yes you need to ground the hood pin wire that goes to the BCM. I've haven't done done one of these so short of someone else adding more exact information. I believe you can use the info in this pictorial of a 2015-2019 F-150 install to accomplish your task, just skip down to the pictures of the hood latch.
https://www.the12volt.com/installbay/forum_posts.asp?tid=145398
bluefrgcaraudio
Posted: July 02, 2019 at 5:57 PM / IP Logged Link to Post Post Reply Quote bluefrgcaraudio
You are correct, it does not give any hood open warnings. Ok, thank you, I will follow those and see what I an figure out. I will post on here what happens. Thanks again
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
