2009 Acura TSX w/Navigation Stereo Wiring Diagram
migpatino
Posted: July 06, 2019 at 12:31 PM / IP Logged Link to Post Post Reply Quote migpatino
Does anyone know the color codes or have the wiring diagram for the stereo on the 2009 acura tsx with navigation . They sell wiring harnesses for the tsx without navigation however, I would like to swap out the stereo for the tsx with navigation
Platinum - Posts: 13,725
Posted: July 07, 2019 at 9:38 AM / IP Logged Link to Post Post Reply Quote i am an idiot
On the speaker wiring they do give you 2 scenarios. Look for these colors in your harness.
Radio 12V      white      +      radio, gray 24 pin plug, pin 24
Radio Ground      black      -      radio, gray 24 pin plug, pin 12
Radio Ignition      violet      +      radio, gray 24 pin plug, pin 14
Radio Illumination      gray (parking lights); red (dimmer)      +,-      radio, gray 24 pin plug, pins 13, 1
Factory Amp Turn-on      white      +      radio, gray 24 pin plug, pin 17
Power Antenna      black      +      radio, gray 3 pin plug, pin 3
Left Front Speaker (+/-)      green - red or red - white      +,-      radio, gray 24 pin plug, pins 23 - 22           Notes
Right Front Speaker (+/-)      green - red or black - green      +,-      radio, gray 24 pin plug, pins 19 - 18           Notes
Left Rear Speaker (+/-)      brown - yellow or violet - yellow      +,-      radio, gray 24 pin plug, pins 11 - 10           Notes
Right Rear Speaker (+/-)      pink - blue or blue - orange      +,-      radio, gray 24 pin plug, pins 7 - 6           Notes
Center Channel (+/-)      red - white (ELS Surround)      +,-      radio, gray 8 pin plug, pins 4 - 2           Notes
Subwoofer (+/-)      green - red or black - green      +,-      radio, gray 8 pin plug, pins 8 - 6           Notes
Aux. Audio Input Left (+/-)      red - black      +,-      radio, gray 20 pin plug, pins 13 - 3
Aux. Audio Input Right (+/-)      white - black      +,-      radio, gray 20 pin plug, pins 14 - 3
RSE Audio Left (+/-)      black - red (USB, XM audio)      +,-      radio, white 14 pin plug, pins 6 - 14
RSE Audio Right (+/-)      green - white (USB, XM audio)      +,-      radio, white 14 pin plug, pins 5 - 13
Satellite Radio 12 Volts      white      +      XM Receiver behind RR seat, wht 14 pin plug, pin 1
Satellite Radio Ground      black      -      XM Receiver behind RR seat, wht 14 pin plg, pin 11
Satellite Radio Ignition      green      +      XM Receiver behind RR seat, wht 14 pin plug, pin 2
Satellite Radio Antenna      (coaxial cable)
Satellite Audio Left (+/-)      black - red      +,-      XM Receiver, white 14 pin plug, pins 6 - 14
Satellite Audio Right (+/-)      green - white      +,-      XM Receiver, white 14 pin plug, pins 5 - 13
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
