2004 Hyundai Tiburon GT, Wires Got Cut To and From Factory Amp
ozzyrules420
Member - Posts: 11
Posted: August 24, 2019 at 3:59 PM / IP Logged Link to Post Post Reply Quote ozzyrules420
ok so here is my problem someone cut the harnesses off of my factory amp well both of them and i was wondering if anyone knows or could tell me what wires went to which pin on the harness so i can fix them?
Platinum - Posts: 13,723
Posted: August 25, 2019 at 10:24 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Are you trying to put the factory radio, or an aftermarket?
ozzyrules420
Member - Posts: 11
Posted: August 25, 2019 at 11:10 AM / IP Logged Link to Post Post Reply Quote ozzyrules420
Well my plan was to bypass the factory amp but couldnt find a bypass harness then my buddy decided to help me and just cuts the plugs off with out even thinking about it an I just want to wire it back up I'll use the factory amp to push all the lil speakers and I have a faster market for my subs
Posted: August 25, 2019 at 3:52 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Are you planning on putting an aftermarket deck into the vehicle?
Posted: August 25, 2019 at 3:56 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Radio 12V      red      +      radio harness
Radio Ground      black      -      radio harness
Radio Ignition      yellow      +      radio harness
Radio Illumination      pink/black      +      radio harness
Factory Amp Turn-on      white/orange      +      radio harness
Left Front Speaker (+/-)      white - brown      +,-      radio harness or amplifier           Notes
Right Front Speaker (+/-)      black - yellow      +,-      radio harness or amplifier
Left Rear Speaker (+/-)      blue - red      +,-      radio harness or amplifier
Right Rear Speaker (+/-)      green - orange      +,-      radio harness or amplifier
ozzyrules420
Member - Posts: 11
Posted: August 25, 2019 at 8:51 PM / IP Logged Link to Post Post Reply Quote ozzyrules420
That's already in there I need to know what colors go to what pins on the harnesses that go into the factory amp
Posted: August 25, 2019 at 10:28 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Can't help you with that. But with the above info you should be able to bypass it.
ozzyrules420
Member - Posts: 11
Posted: August 25, 2019 at 11:36 PM / IP Logged Link to Post Post Reply Quote ozzyrules420
Thx bruh I appreciate the info it will help me when I get home tonight
ozzyrules420
Member - Posts: 11
Posted: October 03, 2019 at 3:14 AM / IP Logged Link to Post Post Reply Quote ozzyrules420
Well it took me awhile but I fingered out the wiring yay me
Tuesday, October 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
