2008 Nissan Pathfinder Door Locks
yayay
Member - Posts: 17
Posted: December 02, 2019 at 7:34 PM / IP Logged Link to Post Post Reply Quote yayay
I can't find the doorlock wires on a 2008 Nissan Pathfinder door locks. the truck does have the factory alarm and does not have a intellikey
wirewise
Moderator - Posts: 489
Posted: December 02, 2019 at 8:09 PM / IP Logged Link to Post Post Reply Quote wirewise
POWER LOCK      LT. BLUE (TYPE B), NOTE #1      @ POWER WINDOW Main Switch, ( WHITE, 16-PIN PLUG), PIN 4
POWER UNLOCK      RED/WHITE (TYPE B), Requires Double Pulse, NOTE #2      @ POWER WINDOW Main Switch, ( WHITE, 16-PIN PLUG), PIN 6
NOTE #1: TEST this wire while Turning the KEY in the Drivers Door. This wire will also ARM the FACTORY ALARM.
NOTE #2: TEST this wire while Turning the KEY in the Drivers Door. This wire will also DISARM the FACTORY ALARM.
~wirewise~ Verify all wiring with your meter before making any connections!
yayay
Member - Posts: 17
Posted: December 03, 2019 at 2:09 PM / IP Logged Link to Post Post Reply Quote yayay
key cylinder froze... do these wires need a negative or positive from the remote start unit
wirewise
Posted: December 03, 2019 at 2:15 PM / IP Logged Link to Post Post Reply Quote wirewise
Single negative pulse to lock, double negative pulse to unlock.
Wednesday, October 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
